Author Topic: JEEPWERX CJ7 Buggy Style  (Read 75404 times)
Re: JEEPWERX CJ7 Buggy Style
« Reply #240 on: July 28, 2014, 01:00:38 PM »
I'm running the Spal fan wiring kit with a 40 amp relay.
Not sure if that's another issue now. Maybe starting it on a lower speed will help?
« Reply #241 on: July 28, 2014, 01:11:03 PM »
do you want me to check the fan controls and fans we stock?
« Reply #242 on: July 28, 2014, 01:21:58 PM »
we run the volvo fans on both the cars.  they have a factory 70amp relay pack that has a two circuits for hi / low.  you switch ground to either of the signal wires.  i have a single pull double throw with center off on my dash for hi or low.
wreck wheeling with the fan hawging on high gets annoying.  571 we just hooked up high or low depending on duty.  cant race on low lol
« Reply #243 on: July 28, 2014, 01:33:03 PM »
Ok  thanks mike.
Yes please Arie.
Thanks
« Reply #244 on: July 28, 2014, 01:39:33 PM »
volvo fan is same blade and motor as 2 speed taurus fan, but way better mounting.  the found fan flange bolts to the OE shroud, as it bolts to a new shroud.
« Reply #246 on: July 28, 2014, 02:06:38 PM »
« Reply #247 on: July 28, 2014, 02:19:04 PM »
its a massive 12mb flyer page...
works from my PC
« Reply #248 on: July 28, 2014, 02:31:19 PM »
Got it
Works on my phone
Thanks
I've got some thinking to do tonigjt.
« Reply #249 on: July 29, 2014, 07:50:32 AM »
Still have coolant air bubble issues
Planning to swap thermostats tonight.
Also,
Running a 2 wire alternator.
I may have wired it incorrectly.
Where does the trigger wire go?
Currently it's run to ignition switch. But when master switch is shutoff engine continues to run.
Ugh
seem to recall having this issue when engine was in Cora's jeep
« Reply #250 on: July 29, 2014, 08:10:18 AM »
I may have figured it out.
Last night noticed that when I installed the new alternator I reinstalled the connections opposite.
With this GM 2 wire alternator the one is jumped back to main post and the other is a dash light?
« Reply #251 on: July 29, 2014, 09:16:24 AM »
Charge wire has to go to the battery side of the shutoff; it will run off the alt without a battery.
« Reply #252 on: July 29, 2014, 09:42:54 AM »
his charge wire was correct, but something going on with one of the field wires that was back feeding through the ignition.  All GM alternators are not alike.  that one appears to be what i ran on the CJ and early buggy motor.  one of the terminals jumps to the charge lug, the other is something for an idiot dash light.  charge lug goes to batter side of the disco like you have it.
thing looks good and sounds good,  couple tweaks and it will be good to go.
your cooling issues is either a gay AMC water jacket thing or a stuck shut thermostat.  baffling but motor def has lot of air in it.
« Reply #253 on: July 29, 2014, 09:46:52 AM »
Just thinking out loud...
Radiator design should matter right?
Stock was top and bottom tanks
New design is cross flow.
New thermostat in hand
Water pump on order from Nuway (JIC, or spare at least)
« Reply #254 on: July 29, 2014, 09:52:18 AM »
shouldn't matter.  your cold draw was on the bottom, hot on the top.
