Author Topic: Tow Rig Tires Tech  (Read 34050 times)
Tow Rig Tires Tech
« on: January 31, 2017, 05:34:44 PM »
I need new tires. Bad.
I had 285/75R16 Load D BFG A/T. tend to cups, wore fast, one broke a belt and bulged right before I took them off.
I'm currently running the 295/70R17 Load E Hankook Dynapro ATM. They cups if I slacked on tire rotation. I think I'm pushing 45-50k miles on them now. All around good tires.
I'm wanting to get another set of Hankooks as I'm very happy with them but I figured I'll ask and see what else I should consider
Re: Tow Rig Tires Tech
« Reply #1 on: January 31, 2017, 05:36:37 PM »
Treadwright?
« Reply #2 on: January 31, 2017, 05:41:59 PM »
19.5's!
« Reply #3 on: January 31, 2017, 05:49:15 PM »
19.5's!
Why? And I'll new wheels if I go 19.5
« Reply #4 on: January 31, 2017, 05:59:01 PM »
www.boarwheel.com
ask jared to get you a set of take offs or find them on CL
will last 100K on that truck and total will be cheaper than 4 e rated truck tires that wont last 20K of towing.
http://www.boarwheel.com/evron-67-19-5x6-75/
« Reply #5 on: January 31, 2017, 06:01:39 PM »
« Reply #6 on: January 31, 2017, 07:08:36 PM »
My truck is more of multipurpose use so they're kinda impractical to me as far as I can think of. I'll like those 19.5" if my truck is hooked to a trailer 24/7 tho.
Already a rough riding truck, daily driver, traveling, some off road, snow and ice driving and towing.
Skinny tires will suck badly for me, rutting the yard or get stuck fast. I haven't look hard for what's available for All-Terrain type tread 19.5" tires with around 33 tall by 12.5 width favor.
And to find wheels that I like will be challenging lol
« Reply #7 on: January 31, 2017, 07:25:11 PM »
wide 19.5s are more like a 36-37" tire. all sizes are 70 aspect ratio.
« Reply #8 on: January 31, 2017, 07:54:52 PM »
Treadwright?
While not perfection, they do last reasonably long and balance well. And are pretty cheap.
I've owned 6 sets, I think?! Still running on the Sierra, although time for a new set.
« Reply #9 on: January 31, 2017, 11:04:27 PM »
I got these from Jared over Christmas time, still fighting to get them balanced and trued. Ride is rougher. But, I really wanted something 33"+ tall for highway rpm reduction and there is no reasonable option in an E range 17 that's that height. Hope they last long enough to be worth it. These are 245s. I think Vision makes a nice alum SRW 19.5 rim that's around $200.
If you actually got 45k out of a set of Hankooks, I'd feel hard pressed not to do that again.
« Reply #10 on: February 01, 2017, 02:04:30 AM »
id agree with harry.  i was getting 11-12K miles out of BFG AT E's on my 2001 24valve towing.  flat even wear on the rears with 3 rotations.  burned up 2 new sets after the set that came on the truck before i went 19.5's
wnyjpgy
« Reply #11 on: February 01, 2017, 07:33:57 AM »
As long as there's a tire conversation going on.....
I know a few of you have tire hook ups..  Do any of you ever come across low profile 22.5?
Regardless of new of used, I'll probably be looking for a set of 4 for drives on my motorhome.
Just curious, any information is appreciated.
Thanks.
« Reply #12 on: February 01, 2017, 08:38:58 AM »
snip
I'll need to pull out my receipts to find what odometer reading when mounted new.
They sounds like exactly what you was looking for? Hankook Dynapro ATM 295/70R17 are 33.3" tall, pretty much why I went with them haha
https://tiresize.com/tires/Hankook/Dynapro-ATM-295-70R17.htm
although 285/70R17 are cheaper and 32.8" tall and much more common size than 295s
I can't fit anything bigger than ~33" diameter spare tire under the bed so 33" diameter tires is a good size for me all around.
« Reply #13 on: February 01, 2017, 08:43:03 AM »
I think you need a spacer for anything wider than 285 with a dually, not something I was willing to do
« Reply #14 on: February 01, 2017, 08:50:48 AM »
oh. that's right. I agree, spacers on dually sounds bad idea.
