Classifieds
Wanted
Help help help! Need driveshaft
Pages: [
Topic: Help help help! Need driveshaft (Read 3467 times)
jacel86
Free Loader
on:
December 13, 2016, 02:47:54 PM »
If anyone could help me out I'd be indebted! Have a Cherokee at our shop that needs a rear driveshaft. Our suppliers sent what they thought it needed but was way too short, and incorrect hardware.
Anything used around that I could sent measurements for and compare?
Re: Help help help! Need driveshaft
Reply #1 on:
December 13, 2016, 02:57:09 PM »
specs on the jeep may help those who might have one. year, engine, trans, case, rearend? not sure if 2dr/4dr are same wheelbase or not, I think they are, but may as well throw it in. and what color - definitely important.
jacel86
Free Loader
Reply #2 on:
December 13, 2016, 03:00:28 PM »
99 jeep Cherokee. 4dr. Np231 and unsure of Chrysler or Dana 35? Pic included. 4.0, auto. Shaft length 36" with double cardan joint.
jacel86
Free Loader
Reply #3 on:
December 13, 2016, 03:00:56 PM »
Reply #4 on:
December 13, 2016, 04:01:46 PM »
thats a custom shaft, probably a front that was re tubed shorter with the addition of a slip yoke eliminator.
harry or spencer would know best if there is some application of a front shaft that is a direct fit.... i have a few on the shop floor, all needing CV rebuild.
What is the shafts problem?
Reply #5 on:
December 13, 2016, 04:14:04 PM »
4 door auto XJ with slip yoke eliminator should use a stock front shaft there.
unfortunately I dont have one around.
Reply #6 on:
December 13, 2016, 04:15:37 PM »
what is the problem?
they arent bad to rebuild. I assume the CV centering ball in the double cardan is wasted (normal). Ive rebuilt them before with good success.
jacel86
Free Loader
Reply #7 on:
December 13, 2016, 04:17:59 PM »
Tons of play in the tube and part of the front of the shaft is broken letting fluid leak. Not to sound dumb....but that's a SYE? Looked like a slip yoke to me, unless I'm just used to seeing a different style in my Rubicon.
Edit: just realized how dumb that sounds now. having the slip mid shaft would mean that would have to be an SYE correct? Well heres a better picture of the main problem (the sloppy shaft being secondary I guess)
Last Edit: December 13, 2016, 04:25:43 PM by jacel86
jacel86
Free Loader
Reply #8 on:
December 13, 2016, 04:26:11 PM »
Leaking from here.
Free Loader
Reply #9 on:
December 13, 2016, 04:27:23 PM »
That is a SYE yoke, albeit not a proper one. Rubicon likely had a flange instead of yoke.
What about pulling the front shaft and putting in the rear for a temp solution?
jacel86
Free Loader
Reply #10 on:
December 13, 2016, 04:32:09 PM »
Customer isn't stranded...but we don't exactly excel in custom fixes. Need to know exact parts to get. Will we need to take the flange off? Whole tailhousing of transfer case?
Free Loader
Reply #11 on:
December 13, 2016, 04:42:42 PM »
That yoke has no seal provision. Can't help with part numbers without interwebs...
Is there branding on the aluminum tail housing?
Reply #12 on:
December 13, 2016, 05:04:11 PM »
looks like an improperly executed Hack n Tap
no seal provision is correct. need more info, this issue apparently did not just occur on its own lol
jacel86
Free Loader
Reply #13 on:
December 13, 2016, 05:05:27 PM »
Seal probably bad, but actual Metal sleeve is broken, not sure if you can see what i mean.
Absolutely no numbers on tailhousing as far as i can see.
Free Loader
Reply #14 on:
December 13, 2016, 05:10:32 PM »
The seal surface should be a lot longer.
Here is a link to a
Quadratec unit
. $40
Pages: [
Classifieds
Wanted
