Author Topic: Help help help! Need driveshaft  (Read 3456 times)
« on: December 13, 2016, 02:47:54 PM »
If anyone could help me out I'd be indebted! Have a Cherokee at our shop that needs a rear driveshaft. Our suppliers sent what they thought it needed but was way too short, and incorrect hardware.
Anything used around that I could sent measurements for and compare?
Re: Help help help! Need driveshaft
« Reply #1 on: December 13, 2016, 02:57:09 PM »
specs on the jeep may help those who might have one. year, engine, trans, case, rearend? not sure if 2dr/4dr are same wheelbase or not, I think they are, but may as well throw it in. and what color - definitely important.
« Reply #2 on: December 13, 2016, 03:00:28 PM »
99 jeep Cherokee.  4dr. Np231 and unsure of Chrysler or Dana 35? Pic included.  4.0, auto. Shaft length 36" with double cardan joint.
« Reply #3 on: December 13, 2016, 03:00:56 PM »
« Reply #4 on: December 13, 2016, 04:01:46 PM »
thats a custom shaft, probably a front that was re tubed shorter with the addition of a slip yoke eliminator.
harry or spencer would know best if there is some application of a front shaft that is a direct fit.... i have a few on the shop floor, all needing CV rebuild.
What is the shafts problem?
« Reply #5 on: December 13, 2016, 04:14:04 PM »
4 door auto XJ with slip yoke eliminator should use a stock front shaft there.
unfortunately I dont have one around.
« Reply #6 on: December 13, 2016, 04:15:37 PM »
what is the problem?
they arent bad to rebuild. I assume the CV centering ball in the double cardan is wasted (normal). Ive rebuilt them before with good success.
« Reply #7 on: December 13, 2016, 04:17:59 PM »
Tons of play in the tube and part of the front of the shaft is broken letting fluid leak. Not to sound dumb....but that's a SYE? Looked like a slip yoke to me, unless I'm just used to seeing a different style in my Rubicon.
Edit: just realized how dumb that sounds now. having the slip mid shaft would mean that would have to be an SYE correct? Well heres a better picture of the main problem (the sloppy shaft being secondary I guess)
« Last Edit: December 13, 2016, 04:25:43 PM by jacel86 »
« Reply #8 on: December 13, 2016, 04:26:11 PM »
Leaking from here.
« Reply #9 on: December 13, 2016, 04:27:23 PM »
That is a SYE yoke, albeit not a proper one. Rubicon likely had a flange instead of yoke.
What about pulling the front shaft and putting in the rear for a temp solution?
« Reply #10 on: December 13, 2016, 04:32:09 PM »
Customer isn't stranded...but we don't exactly excel in custom fixes. Need to know exact parts to get. Will we need to take the flange off? Whole tailhousing of transfer case?
« Reply #11 on: December 13, 2016, 04:42:42 PM »
That yoke has no seal provision.  Can't help with part numbers without interwebs...
Is there branding on the aluminum tail housing?
« Reply #12 on: December 13, 2016, 05:04:11 PM »
looks like an improperly executed Hack n Tap
no seal provision is correct.  need more info, this issue apparently did not just occur on its own lol
« Reply #13 on: December 13, 2016, 05:05:27 PM »
Seal probably bad, but actual Metal sleeve is broken, not sure if you can see what i mean.
Absolutely no numbers on tailhousing as far as i can see.
« Reply #14 on: December 13, 2016, 05:10:32 PM »
The seal surface should be a lot longer.
Here is a link to a Quadratec unit. $40
