Author Topic: m4 CJ7  (Read 30403 times)
Re: m4 CJ7
« Reply #45 on: December 22, 2016, 07:13:10 AM »
Re: m4 CJ7
« Reply #47 on: December 23, 2016, 11:50:18 PM »
found better, from FB- code BUYNOW gets another savings from 4wd.com
193 per tire shipped thats crazy
Re: m4 CJ7
« Reply #48 on: December 23, 2016, 11:54:47 PM »
ordered! o boy
Re: m4 CJ7
« Reply #49 on: December 24, 2016, 08:17:50 AM »
Score!
Re: m4 CJ7
« Reply #50 on: December 26, 2016, 06:27:23 PM »
fuel sender installed in tank
HEI 1 wire dist installed
close to fire point.
Re: m4 CJ7
« Reply #51 on: December 27, 2016, 11:18:24 PM »
ebay steering column shaft minus 2 bolts for 39$ showed up today
HEI 1 wire distributer set and powered
fire wall block pined out and critical items cleaned up and run
battery installed
fired and idled on starting fluid.
not sure how dash gets ground yet- only headlights and right blinker working, ignition and crank also worked with minimal effort.
new trans pan gasket leaks FML
with a fuel tank installed and tacase should be mobile on its own soon.  sick of pushing in and out to swap bays lol
Re: m4 CJ7
« Reply #52 on: December 28, 2016, 06:33:36 PM »
new steel tank hung
motor fired and timing set, adjustments and fiddles- sounds strong.  heat cycled
mini air cleaner and fuel filter installed.
steering gear leaks- bah
column locked up- i guess i need keys
3 wheels showed up
tires tomorrow
4th wheel friday
still need to source a 300 and then can test trans / move.
electrical for signals looks pretty hacked and will need pretty complete rewire.
Re: m4 CJ7
« Reply #53 on: December 29, 2016, 09:58:48 PM »
looks like Matt found me a good D300 and will bring home from PA this weekend
tires and 4th wheel at my door tonight when i returned from Buffalo.
Mounted up with beads and on the jeep.  lift, tires, wheels, backspace- all look great.  very happy.
Re: m4 CJ7
« Reply #54 on: December 30, 2016, 07:03:35 AM »
looks sweet! love the old school wheels
Re: m4 CJ7
« Reply #55 on: December 30, 2016, 02:05:29 PM »
Nice!
Re: m4 CJ7
« Reply #56 on: December 30, 2016, 06:30:59 PM »
auto trans linkage cluster rebuilt, frame bracket fabed and locked to frame.  Linkage extended for body lift.
auto column tail bearing, bearing retainer, baring flange replaced
Re: m4 CJ7
« Reply #57 on: December 30, 2016, 06:34:08 PM »
also fun fact: when mounting 2.5" back spaced wheels you have to mount them backwards- humped on one for 30 minutes then after checking that i didn't get sent 16" rims instead of 15", decided to try from the other direction because the indent was closer, fell right on as it should have in the first place.
Re: m4 CJ7
« Reply #58 on: December 30, 2016, 08:34:06 PM »
The drop center is your friend.
Re: m4 CJ7
« Reply #59 on: January 01, 2017, 09:50:54 AM »
interior seats and console bolted in yesterday
I fit in a CJ7 much better lol
