Author Topic: TDI Wonder 2.0  (Read 92961 times)
Re: TDI Wonder 2.0
« Reply #90 on: December 11, 2022, 02:11:52 PM »
Well that’s interesting
« Last Edit: December 12, 2022, 09:20:07 AM by etk300ex »
Re: TDI Wonder 2.0
« Reply #91 on: December 11, 2022, 06:41:35 PM »
those pieces look extra but semi important
Re: TDI Wonder 2.0
« Reply #92 on: December 12, 2022, 09:03:15 AM »
they work better as one piece, apparently
Re: TDI Wonder 2.0
« Reply #93 on: December 12, 2022, 09:19:52 AM »
Back to starting status.  Got a starter from AZ this time, but its the same exact unit as the Carquest.  Looking on RA, they all appear to be the same unit.  No options for name brand.
I think it's been broken for a while.  I've been chalking the extra noise up to cold start and low battery.  It all makes sense now.  After the car was warm, it didn't make any excessive noise.  Flywheel has some chips, but nothing major.
Found the hub centric rings that I though I had for the winter wheels, laying in my back yard ::)
Re: TDI Wonder 2.0
« Reply #94 on: January 25, 2023, 03:45:45 PM »
Inspection achieved!
I would like to fix the ABS.  Mike will your scanner identify the issue?
Re: TDI Wonder 2.0
« Reply #95 on: January 25, 2023, 04:16:04 PM »
will identify what faults ABS computer thinks there are, yes. I don't have it with me today so can't do it at the meeting.
Re: TDI Wonder 2.0
« Reply #96 on: January 25, 2023, 04:25:37 PM »
You don't carry it on you everywhere you go?  I can't make it tonight anyhoo.  I can stop by one of these weekends.
I don't recall if the light has always been on or not.
Re: TDI Wonder 2.0
« Reply #97 on: January 25, 2023, 04:49:20 PM »
I know mine is, as of this driving season. Hasn't been on forever. On that one, I think it's been on since that rear wheel bearing maybe? I think I remember we did one but the other threw an error too maybe? don't think I saved the scan but it might be on my desktop on that laptop.
I do carry it all the time in the beemer since the transmission issues, but this one has been happy so its stayed in the shop
Re: TDI Wonder 2.0
« Reply #98 on: February 01, 2023, 09:12:23 AM »
95% sure the starter has grenaded itself again.  Same issue as last time, weak starts, extra noise.  Last night, the big noise.  I can't find this issue online anywhere.
Re: TDI Wonder 2.0
« Reply #99 on: February 07, 2023, 09:14:38 AM »
Not grenaded.  Bench tests ok.  Shaft seems a bit floppy to me for how it's designed to work, but I don't recall how it was when I put it in.  Ordered a Bosch starter as they are available now.  Last resort before something major needs to be addressed.  Lots of comments for failed carquest, duralast, no name brand starters online.
Re: TDI Wonder 2.0
« Reply #100 on: February 11, 2023, 08:12:54 AM »
Bosch installed and works as it should.  I’d be lying if I said it sounds great, but it’s not skipping.  It is much heavier than the cheapos and there is zero shaft play.
Re: TDI Wonder 2.0
« Reply #101 on: April 12, 2023, 09:22:36 AM »
Uneventful road trip to Philly and back.  Roads are fucked!
Re: TDI Wonder 2.0
« Reply #102 on: August 15, 2023, 06:34:44 PM »
Another one bites the dust!
Re: TDI Wonder 2.0
« Reply #103 on: August 15, 2023, 11:36:59 PM »
oh no... crash or mechanical failure?
Re: TDI Wonder 2.0
« Reply #104 on: August 17, 2023, 08:58:41 AM »
Starter.  Spins, doesnt extend.
