Author Topic: TDI Wonder 2.0  (Read 92937 times)
Re: TDI Wonder 2.0
« Reply #60 on: August 25, 2022, 03:11:34 PM »
no-engage symptom only and no pressure readings it isn't worth guessing.
I don't know if VW will spin an empty system or not.
Re: TDI Wonder 2.0
« Reply #61 on: August 25, 2022, 03:14:25 PM »
I have a hose/gauge thingy for R134 cans.  I could see if it has any pressure I suppose.
Re: TDI Wonder 2.0
« Reply #62 on: September 12, 2022, 02:46:15 PM »
AC pressure = 0psi
Drove this machine a lot last week.  Goes down the highway 80mph straight and smooth which I find impressive for a car with 230k that's had the rear end of the car welded onto it lol.
Re: TDI Wonder 2.0
« Reply #63 on: November 08, 2022, 08:59:21 AM »
7 calls to find Mobil Delvac for this unit.  TSC has 1 jug.
Re: TDI Wonder 2.0
« Reply #64 on: November 08, 2022, 09:00:31 AM »
Not even on Amazon unless you want to pay quadruple.
Re: TDI Wonder 2.0
« Reply #65 on: November 08, 2022, 09:17:21 AM »
order cancelled ::)
Re: TDI Wonder 2.0
« Reply #66 on: November 08, 2022, 09:40:36 AM »
Ruh roh
I have some on the shelf but if I can't replace it it's not going to be available.
I last stocked up at BJ's off the shelf in Henrietta for a totally normal price in late spring. Maybe holler at Arie and see if Hahn has stock if it's really limited for some reason?
Pretty much any decent diesel oil is fine, these don't have the fragile camshafts of the later TDIs that need the super fancy oil.
I interchange Delvac 1300, Rotella T, or any name brand that meets the somethingsomething 5 spec
Re: TDI Wonder 2.0
« Reply #67 on: November 08, 2022, 09:50:04 AM »
Yeah, I'll have to look for something else.  I have a half gallon of Delvac so I wanted to stick with it.
Re: TDI Wonder 2.0
« Reply #68 on: November 14, 2022, 09:37:12 AM »
Mike found Mobil at runnings as I was on my way to runnings.
Drivers mirror light is permanently on now ::)
Re: TDI Wonder 2.0
« Reply #69 on: November 14, 2022, 11:34:01 AM »
In the sun visor? I don’t know where the switch for those is. Dumb failure!
Re: TDI Wonder 2.0
« Reply #70 on: November 14, 2022, 12:02:09 PM »
Yes.  The switch is the mirror sliding door.  It flickers if you operate the door or move the visor around so likely a pinched wire in the visor harness.  It does shut off with the key luckily.
Re: TDI Wonder 2.0
« Reply #71 on: November 21, 2022, 12:27:02 PM »
Not enough juice to start this morning.  Battery @ 55%.  It's been getting weaker an weaker for the last month.  About a year old.  Will have to check for a draw, oy!
Re: TDI Wonder 2.0
« Reply #72 on: November 21, 2022, 12:29:29 PM »
And dip stick tube broke off  ::)
Re: TDI Wonder 2.0
« Reply #73 on: November 21, 2022, 01:31:34 PM »
550cca was low spec to begin with if that was true from our texts.
Re: TDI Wonder 2.0
« Reply #74 on: November 21, 2022, 02:41:24 PM »
Yeah, I looked it up on Rock Auto while I was ordering parts and they spec 650 or 750.
