Author Topic: TDI Wonder 2.0  (Read 88254 times)
Re: TDI Wonder 2.0
« Reply #105 on: September 08, 2023, 09:03:34 AM »
Removed, looks fine visually.  Teeth look fine on the flywheel and the starter.  On the bench, it extends, spins, but doesent retract.  Spin starts slowely and ramps up, maybe because I was using #10 wire...  Sounds like it has gravel inside.
Re: TDI Wonder 2.0
« Reply #106 on: September 08, 2023, 07:14:03 PM »
the gravel part doesn't sound good. no retract usually means it wants some lube. Small wire may be the issue on slow start
Re: TDI Wonder 2.0
« Reply #107 on: September 11, 2023, 11:13:27 AM »
Odd, because it wouldn't extend in the car.
New one will be here today.  Lifetime replacement through FCP Euro.  I confirmed with them that this is the correct starter and there is not a different one for deisel.
Re: TDI Wonder 2.0
« Reply #108 on: September 13, 2023, 09:10:16 AM »
New Bosch installed and it sounds like a normal starting vehicle.  Now I think the last one was not right from the git-go.
Re: TDI Wonder 2.0
« Reply #109 on: September 13, 2023, 07:39:14 PM »
Has been a string of that. I still wonder if there may be something funky with the flywheel that’s killing them. No idea what that could be though
Re: TDI Wonder 2.0
« Reply #110 on: September 14, 2023, 09:43:24 AM »
same
Re: TDI Wonder 2.0
« Reply #111 on: September 28, 2023, 11:08:58 AM »
Mikemike are you going to be in the shop this weekend?  I'd like to hook this thing up to the scanner, pretty sure theres a wheel bearing going out and all the brake warning lights are on.  I don't want to have to fix anything but starters this winter ;D.
Re: TDI Wonder 2.0
« Reply #112 on: September 29, 2023, 12:09:52 PM »
I should be around other than park cleanup saturday. Sunday available for scanning and for lifting and wheel wiggling. I'm 80% sure I have bearings in stock, front and rear. No ABS sensors or calipers stocked though.
Re: TDI Wonder 2.0
« Reply #113 on: October 02, 2023, 10:05:53 AM »
Driver rear wheel bearing replaced. Thanks Mike! I have few of the tool required for this install.  Needs a new VSS.
Re: TDI Wonder 2.0
« Reply #114 on: October 02, 2023, 07:36:09 PM »
Getting pretty quick at these things!
Re: TDI Wonder 2.0
« Reply #115 on: October 03, 2023, 08:17:10 AM »
I ordered both side rear brake lines for stock.
Re: TDI Wonder 2.0
« Reply #116 on: October 03, 2023, 09:38:10 AM »
Good call
I may order a set of the fancy rack crossover and see if I can dupe the fittings that adapt to an-4. I should check the other two racks in my fleet, I’m sure they’re just as crunchy as my wagon where they failed and yours didn’t look great. Hundred bucks a set seems pretty proud to me but I bet it is custom machine work.
Re: TDI Wonder 2.0
« Reply #117 on: October 09, 2023, 09:23:56 AM »
New VSS, die grinder and fire to remove ::)
Re: TDI Wonder 2.0
« Reply #118 on: December 30, 2024, 11:44:55 AM »
Gambled on this Cat https://www.ebay.com/itm/176649062998 in lieu of spending $350.  It wasn't good lol.  Came in two pieces.  Had to cut and reweld the hangers.  Flange wasn't welded on very straight.  Had to grind down welds to fit the nuts on.  Bolts were no where near what's required.  It's good enough for this unit, needs a couple band clamps.
No one in Advance knew what a band clamp was.  Zone didn't either but had one flat one on the shelf.
Re: TDI Wonder 2.0
« Reply #119 on: January 01, 2025, 02:25:06 PM »
It sure smells better in the cab
