Author Topic: 1978 F250 The new Shop shovel!  (Read 49024 times)
Re: 1978 F250 The new Shop shovel!
« Reply #150 on: November 29, 2017, 11:07:33 AM »
so march?
« Reply #151 on: November 29, 2017, 11:54:07 AM »
today my early day out, ill look at it this afternoon.
if i cant match a number it will get a jeep starter motor from the pile thrown on it
« Reply #152 on: November 30, 2017, 09:06:48 AM »
JJ has 2 plow pump assemblies he was just about to scrap ill nab and see if they swap motors!
« Reply #153 on: December 03, 2017, 08:42:30 PM »
ended up being the actual gear to gear oil pump in the hydro unit was seized stalling motor.  swapped the oil pump from a lift assembly JJ gave me all good.
used for 30minutes plus to move axles and motors around the shop lot for winter clean up!  she is good to go for another plow season!
« Reply #154 on: December 31, 2017, 12:03:02 PM »
calling it on this thing, last winter for it.  getting cut up in 2018
dont have the tolerance to change wires, plugs, heavy gage wire, and starter motor, set timing correctly, and add a block/oil heater.
just doesnt like the cold any more.
« Reply #155 on: December 31, 2017, 12:14:10 PM »
Sure it’s not just timing off from the ignition change? I don’t know why I’m asking. I’m sure you’re sure.
« Reply #156 on: December 31, 2017, 12:17:20 PM »
im not sure on the timing, it has no marks, and where it runs plus or minus 20 degrees there is no change in operation
the plugs look horible and it may not even be running on 8 when it runs, they look like they dont want to come out, havent tried.
« Reply #157 on: December 31, 2017, 12:26:45 PM »
No marks and plugs that don’t want to come out sounds like no fun when it doesn’t fit in the shop to work on warm.
« Reply #158 on: December 31, 2017, 12:31:10 PM »
id rather put chains and the CJ7 on the back of the 49 with a plow after adding some heat and defrost to it at this point
« Reply #159 on: December 31, 2017, 01:00:52 PM »
Amen
Callelle
« Reply #160 on: June 03, 2018, 07:35:40 PM »
Farewell, sweet prince.
« Reply #161 on: June 03, 2018, 07:57:51 PM »
nice!  make money on it?
Callelle
« Reply #162 on: June 03, 2018, 08:19:13 PM »
Not quite yet. I sold the truck for $600, which considering there's no bed or front axle, I don't think that's too bad. I also sold the $10 autozone mirrors for $50. I still have the wrecker body, plow, and beacon to get rid of. I was originally excited to try and make money, but it's a pain when my shop is 40 mins from my apartment, so I'll be happy if I can break even.
