Author Topic: 1978 F250 The new Shop shovel!  (Read 49058 times)
Re: 1978 F250 The new Shop shovel!
« Reply #120 on: March 14, 2017, 08:52:38 PM »
blew the reverse shifter fork apart in this unit.  Fuck
didnt make it over to my drive way before it happened.  no good.  lots of snow. bah
looking for a ford T18 top end (3 fork version 79 and newer T18, cast iron top not alum (NP435))
« Reply #121 on: March 15, 2017, 10:43:30 AM »
nothing I would have here..
« Reply #122 on: March 15, 2017, 07:13:15 PM »
fork pulled this afternoon and given to the tig surgen,  hoping to grab tonight.  The driveway situation is terrible with morons
as a back up i found a company in Florida that had the fork and pad in stock for 34$ shipped.  sadly any kind of expedited shipping was 100$ or so more/  bah
« Reply #123 on: March 16, 2017, 09:17:29 AM »
I think you have time to get that $34 one from florida now :)
« Reply #124 on: March 16, 2017, 10:15:37 AM »
I have a welded fork back in hand now ill thow in this afternoon if i can cob up a fork pad from 231 parts or try to dig the original out from the bottom of trans sump
« Reply #125 on: March 16, 2017, 08:42:19 PM »
tried to cob a 231 pad onto the welded fork would not work.  ran it with no pad, works fine.  back in business
new fork and pad shipped today so ill swap it out next week or whenever it decides to fail again.
adjusted the clutch linkage which so no more grinding which is probably what caused the failure in the first place.
back to a snow pushing machine!
« Reply #126 on: May 10, 2017, 01:31:22 PM »
this thing has been working hard this week-  picking van cabs up and pushing truck chassis's around.
working well.  May need a in cab carb shot system installed soon for cold starts
« Reply #127 on: November 06, 2017, 10:04:28 PM »
this thing let me down tonight.
cranked with fuel dumped in carb and fired up.  looked like a fire work show under hood near battery cables and starter solenoid so i keyed off after 20 seconds of running.  then dead.
no key tocrank, jumped starter solenoid for crank but no ignition power.  bah.  if its more than wires or fuses its getting the torch.  sick of non fuel injection no heat pos.  might need to build a shop truck.
« Reply #128 on: November 07, 2017, 10:05:53 AM »
wonder if it just killed the battery or the solenoid with a dead short?
« Reply #129 on: November 07, 2017, 11:52:11 AM »
it cranks fine with a crescent wrench handle against the starter solenoid, but no fire with key on, so i suspect what ever blew killed the feed to the key which feeds sig to the starter solenoid and the coil.
no crank signal and no coil power.
was cold and dark so it got the hood shut.  have about 5 heavy things needing moving, but i guess i should have pulled it out of hypernation before we see 20s earlier
« Reply #130 on: November 07, 2017, 01:09:51 PM »
Sounds right and likely.
« Reply #131 on: November 09, 2017, 02:00:15 PM »
had a half hour of day light yesterday and found the charred wires / sparky area.  looks like it was just a wadded up junction of alternator feed, dash feed, and other power feeds that had failed.  Fixed and now its back cranking but no fire.
verified key on power to coil
must have fried distributor or duraspark module.
looks like there are some tests but they require pulling the distributor.
30$ for a new module (wiring looks suspect everywhere)
48$ for an Hei one wire distributor to bi pass it all.......
need to identify motor if its a small block or big block, and what displacement i guess.
« Reply #132 on: November 09, 2017, 02:13:19 PM »
If I remember correctly it's Ford 400m small block.
« Reply #133 on: November 09, 2017, 02:23:26 PM »
thats what i was told, but who knows
http://www.fordification.com/tech/engineID-V8.htm
i hate fords
« Reply #134 on: November 09, 2017, 09:30:58 PM »
confirmed its a 400 as best i can, ordered a 41$ HEI distributor for it lol
