Author Topic: Toms Rubicon oil pan  (Read 42745 times)
« on: May 01, 2016, 09:28:54 AM »
While wheeling at RC, I found out the hard way the oil pan is not a skid plate. Now I need to replace the pan. Do I need to replace the rear main seal at this time also or just the pan and gasket. While I'm on the subject ,SMike do you still have the template for a full skid you did for Tony's rubicon?
Re: Toms Rubicon oil pan
« Reply #1 on: May 01, 2016, 09:39:56 AM »
Replace the seal if it is leaking.  Otherwise, just the oil pan gasket.
Do you really need a full skid?  With a manual, just the oil pan should be sufficient.  The Nth Degree oil pan skid I had was awesome.  What about just plating a stock oil pan with a little sump armor?
« Reply #2 on: May 01, 2016, 01:43:47 PM »
smile armored up mine after i did the same think on rock creek 2-3 years ago..
leave the seal if you weren't leaking before the strike
« Reply #3 on: May 01, 2016, 02:36:50 PM »
Callelle
« Reply #4 on: May 01, 2016, 03:13:28 PM »
That's the Nth degree pan that I have on my XJ. Aside from the fact that its the only skid I could find that would work with long arms, I like how it's built and how it mounts, and doesn't cause any interference with the drain plug. If you want,  I can send you some pictures of mine.
« Reply #5 on: May 01, 2016, 03:57:58 PM »
Cool
« Reply #6 on: May 02, 2016, 07:48:13 AM »
So what's the difference between a Dorman $52 pan and a mopar $151
« Reply #7 on: May 02, 2016, 08:23:49 AM »
for what it means to you . . .  $99
« Reply #8 on: May 04, 2016, 08:16:26 PM »
« Reply #9 on: May 04, 2016, 08:17:04 PM »
If the pan was in better shape I might have been able to patch it and continue to wheel.
« Reply #10 on: May 04, 2016, 08:44:34 PM »
That's some crusty nastiness...
« Reply #11 on: May 04, 2016, 09:12:40 PM »
Yeah it's only bad on the front of the L. The back side is still smooth.
« Reply #12 on: May 05, 2016, 09:13:44 AM »
at least it prelubed those stupid converter flange bolts for ya!
« Reply #13 on: May 05, 2016, 04:46:48 PM »
I sprayed those down 3 times since Saturday. All came out nice.
« Reply #14 on: May 05, 2016, 04:47:38 PM »
Here's the gasket and a trick set of standoffs
