Author Topic: Toms Rubicon oil pan  (Read 42746 times)
Re: Toms Rubicon oil pan
« Reply #15 on: May 05, 2016, 04:49:24 PM »
Bag says to place in 4 corners and click the gasket to them. Then install pan and when left with only 4 corners unscrew and place correct bolt in place
« Reply #16 on: May 05, 2016, 04:50:30 PM »
And rtv the front and rear u shaped sections ,plus add rtv to rear main seal to fill in a gap.
« Reply #17 on: May 05, 2016, 04:52:59 PM »
Want to come do mine now? :-)
« Reply #18 on: May 05, 2016, 04:58:35 PM »
I am still in the process of this one. I didn't even attempt trying to get the cat and muffler apart i just used the sawzzall and will use a good union for the exhaust. i didn't want to drop my rainbow shaped shovel and not have it go back up once it sprang free.
« Reply #19 on: May 05, 2016, 05:36:42 PM »
Hahaha...good point
« Reply #20 on: May 06, 2016, 11:49:24 PM »
Home stretch now. Have the pan installed that went fairly straight forward. Took SMike advice and just past hand tight. Need to get the exhaust taken care of Saturday.
« Reply #21 on: May 07, 2016, 06:15:33 PM »
Drove around the block, check for leaks in a few min. Had to stop to cook dinner
« Reply #22 on: June 29, 2016, 08:57:50 PM »
About to tackle mine in the next week or so. Any advice tom?
Kinda thinking about mooching the exhaust idea Erik and Cora used from Gif.
« Reply #23 on: June 29, 2016, 09:44:39 PM »
That's a great option on the exhaust. I used thread to tie the gasket in place,you can also you tac spray.
« Reply #24 on: June 29, 2016, 10:25:35 PM »
3M adhesive that bitch to the oil pan
