Author Topic: Power steering swap kit for 1973 CJ5 I6  (Read 2954 times)
« on: July 08, 2015, 11:10:57 AM »
looking for power steering pump brackets, or full buy it now kit for 258
Re: Power steering swap kit for 1973 CJ5 I6
« Reply #2 on: July 09, 2015, 10:01:21 AM »
« Reply #3 on: July 09, 2015, 02:07:41 PM »
JB weld
« Reply #4 on: July 09, 2015, 02:26:46 PM »
just a stock photo kept for comparison, no relevance
« Reply #5 on: July 09, 2015, 03:39:17 PM »
well I have everything but eh brackets in stock..
also.. the cast iron frame mount for 72-75 jeeps is sometimes like hens teeth to find..  just FYI...
« Reply #6 on: July 09, 2015, 04:50:10 PM »
Eds jeep is a TDK frame, so the cast mount that slips inside the frame rail as i recall wont work.  I think the later ones showed in the CL add above would be best bet
« Reply #7 on: July 09, 2015, 05:41:49 PM »
I have 2 engines kicking around here.
What year?
« Reply #8 on: July 27, 2015, 04:43:18 PM »
its looking like we will end up swapping the intake on eds jeep.  it needs to be a 2bb intake with the holes inline parallel to the cylinder holes
0 0 0 0 0 0
      o o
« Reply #9 on: July 28, 2015, 10:25:12 AM »
I might have one on parts CJ..
« Reply #10 on: July 28, 2015, 10:33:09 AM »
i believe its the kind that bolts through to the exhaust manifold with 4 studs like my 75 had
« Reply #11 on: August 20, 2015, 09:23:56 AM »
erik, what engines you have and what $$ you need?  looking at options to keep Eds cost down.  the jeep will be in the shop first week of September to do this swap.
« Reply #12 on: August 20, 2015, 10:29:52 AM »
I have 1- 1985 4.2 with power steering intake. It came out of the propane powered cj buggy.
Sitting on a carpet dolley.
I'd like to sell the complete motor.
How's 200.00?
« Reply #13 on: August 20, 2015, 10:41:07 AM »
did this motor run well?
« Reply #14 on: August 20, 2015, 10:44:30 AM »
I40k miles when speedo was removed for buggy use.
Low compression but mechanically sound.
Good candidate for rebuild
