Author Topic: Power steering swap kit for 1973 CJ5 I6  (Read 2956 times)
Re: Power steering swap kit for 1973 CJ5 I6
« Reply #15 on: August 20, 2015, 10:55:52 AM »
can you post a picture of the intake from top side when you get a chance.
i assume no power steering pump?  i need the crank pulley, and PS pulley, brackets, intake ect
« Reply #16 on: August 20, 2015, 11:00:51 AM »
Sure I'll take on tonight when I get back.
I can see what parts I have on the shelf.
Just off the top of my head...
New can of ham style res.
AGR Power steering box.
Power steering box drilled and tapped unknown brand
AGR Pump
Ram
I'll confirm what I have.
It's all gotta go.
« Reply #17 on: August 26, 2015, 05:08:46 PM »
hmmm
jeep will be here next Monday!  need to figure this out haha
« Reply #18 on: August 31, 2015, 10:25:14 AM »
looking at this- i think his alternator needs to move to the other side.
ill think it will be easier to just grab this motor from you if it has the alternator brackets too.
do you have a single plane steel power steering pump pulley to throw in?
« Reply #19 on: August 31, 2015, 12:54:02 PM »
these pullys are NOT ALL THE SAME..
« Reply #20 on: August 31, 2015, 01:03:18 PM »
just a P pump, every one i have ever taken off is the same jeep and chevy v belt.  dual or single will work
if not i can grab one from J&J or dig harder for one i might have.
« Reply #21 on: August 31, 2015, 01:28:27 PM »
watch the offset..  went through several pulley on the 360 before I found the correct one..
early pumps are key.. later are press on..
« Reply #22 on: August 31, 2015, 01:57:35 PM »
ah, ill update my PN then i just want a 4 bolt press p pump.  was wondering why Advance auto shows a key'd pulley for 40$
« Reply #23 on: August 31, 2015, 02:19:45 PM »
then you will need metric to SAE adapter on pressure line....
its a hot mess getting everything right...
most of these parts will be special order.. I can get but don't know when jeep is coming in
« Reply #24 on: August 31, 2015, 02:25:58 PM »
its really not- its all chevy and same jeep crap used for 35 years- ill just ignore its a 73.  was trying to use PN that when yahoo looks it up to later replacement they match
ive done this twice before- first time ran into the manifold not having required boss bolts though.
« Reply #25 on: August 31, 2015, 02:26:50 PM »
jeep here today
« Reply #26 on: August 31, 2015, 02:44:31 PM »
I wonder if 87-90 YJ 258 will be better
« Reply #27 on: August 31, 2015, 02:54:26 PM »
could be...  i really didnt pushing getting parts, because the other really nice wrench thrown into it.... its a TDK frame.  have no idea what OEM mount holes or brackets will fit.
Plan on taking the week to just get parts im sure ill be running around a bit.
« Reply #28 on: August 31, 2015, 03:30:17 PM »
I didn't realize it was that complicated, we shoulda pulled the power steering stuff off the parts Eagle before I sent it down the road.
« Reply #29 on: August 31, 2015, 04:39:43 PM »
there is a CJ7 in my lot too for reference :)
