Author Topic: MMTR Brolite  (Read 94779 times)
Re: MMTR Brolite
« Reply #315 on: October 08, 2016, 10:38:19 PM »
I was thinking the same. Maybe for ranger, maybe for jeep junk? I don't want to get much more if any rate of course. Just more sit-in at similar ride height. They're usually really high rate too.
Re: MMTR Brolite
« Reply #316 on: October 10, 2016, 11:31:21 AM »
reminder for shock $$, i had forgotten and will forget again so posting here to remind us.
looks like 4.5 sticks of tube left?  thats ~150$ off the 470$ tab?
ill keep it all unless you want more.  no matter to me.
Re: MMTR Brolite
« Reply #317 on: October 10, 2016, 12:36:49 PM »
sounds right. I'll probably need a bit more for front clip mounts (might as well gut them now that they need straightening) and rear bumper braces.
Re: MMTR Brolite
« Reply #318 on: November 04, 2016, 06:18:19 PM »
are it from the trailer to the garage. On deck...
Re: MMTR Brolite
« Reply #319 on: May 20, 2017, 10:27:19 PM »
Clutch feels fine. Wtf?
Reminded myself that it's a hydraulic throwout. No pivot issues or so forth.
Overheated fluid growing between master & slave if I was riding the clutch?
I have a really really bad habit of leaving my left foot on the pedal. Maybe I need a really strong return spring.
Re: MMTR Brolite
« Reply #320 on: May 22, 2017, 11:38:16 AM »
identical problem on identical truck. no resolution.
https://www.reddit.com/r/Cartalk/comments/2gy8yc/clutch_overheats_on_97_ranger_ceases_shifting/
I already have pretty fresh fluid from when I did the clutch and the line was cut & spliced (IIRC).
I'm thinking I run it again and see what happens (while being prepared to be sad), and if it does the same thing again, fully replace the hydraulics and put in some high-zoot DOT 5 high temp full synthetic unicorn juice. Any other ideas?
should I try to drain and fill it ahead of time? I guess I'll see how brown the fluid in the reservoir is.
Re: MMTR Brolite
« Reply #321 on: May 22, 2017, 12:23:26 PM »
Wasn't Erik having the very same issue?
Re: MMTR Brolite
« Reply #322 on: May 22, 2017, 12:58:52 PM »
doesn't ring a bell, I'm not sure.
Just ordered some fancy 600Ëš DOT 4 Motul brake fluid. Hopefully that'll be a quick flush & swap.
Re: MMTR Brolite
« Reply #323 on: June 04, 2017, 05:21:51 AM »
Clutch felt funny loading it into the trailer after the second race. Low pedal instead of typical high pedal and very sudden engagement.
Unloaded just now to let the rain wash it for me, and I've got almost no clutch. I can hold it with the brakes and it will idle with the clutch on the floor, but it's partially engaged. The starter won't turn over the engine without letting the truck move.
Any ideas other than just throwing a new master & hydraulic throw out at it?
I'm sure I could bleed it now and it'd last a race but this feels like a new ongoing issue that needs more than fluid changes. I just don't understand the failure at this point.
Master and slave are original to purchase. It got a clutch last year after what could have been the same issue - it was slipping during a race so I changed it.
Re: MMTR Brolite
« Reply #324 on: June 04, 2017, 04:20:39 PM »
Seems strongly related:
Re: MMTR Brolite
« Reply #325 on: June 04, 2017, 04:25:00 PM »
Hmm. Guess that needs a clamp or something.
Re: MMTR Brolite
« Reply #326 on: June 04, 2017, 09:47:05 PM »
i have to say i am very disapointed in the clutches and steering on these trucks.  everything else is way above expecatation.
Mine is getting a chevy steering pump next.  I already have a wilwood master for the clutch.
Re: MMTR Brolite
« Reply #327 on: June 04, 2017, 10:27:52 PM »
With landings from clearing the table top that moved my go pro, and not having the steering give out, I think my chained passenger mount must be good.
I'll probably have to bleed the master but I don't think I'm touching anything else on here before Broome.
Need a straight front clip and some spare tires, and probably a new driver bedside along with more flexible bed mounts.
Re: MMTR Brolite
« Reply #328 on: June 04, 2017, 10:29:57 PM »
Re: MMTR Brolite
« Reply #329 on: June 04, 2017, 10:45:30 PM »
at :26  im motioning to that stupid XJ though my window net to get his ass moving, then i say screw it and just pass him on the line up
moron.
sorry for the mud.  was a good race.
