Author Topic: MMTR Brolite  (Read 93190 times)
Re: MMTR Brolite
« Reply #15 on: March 11, 2015, 07:49:20 AM »
...and Kim's doing work!  Go Kim!
Re: MMTR Brolite
« Reply #16 on: March 11, 2015, 07:54:30 AM »
Did I mention that only the replaced right rear hanger and shackle were still present, all three others had failed? Extra scary. The bad brake line probably saved a bus full of orphans and blind nuns.
Re: MMTR Brolite
« Reply #17 on: March 11, 2015, 07:55:29 AM »
You owned a 40 or less torx and were in a "jeep-ish" club? ?? For shame!!! Lol
He didn't own a jeep silly!
Dakota s have poprivets!
Re: MMTR Brolite
« Reply #18 on: March 11, 2015, 07:56:59 AM »
Does that have a rear swaybar?
Re: MMTR Brolite
« Reply #19 on: March 11, 2015, 07:58:22 AM »
Yup. Seems to be 100% good. Is that not standard issue? It probably had a lot to do with the rearend not entirely vacating the truck
Re: MMTR Brolite
« Reply #20 on: March 11, 2015, 08:17:05 AM »
I'm pretty sure mine didn't have one.
Re: MMTR Brolite
« Reply #21 on: March 11, 2015, 09:07:55 AM »
no sway bar on mine or ryans
Re: MMTR Brolite
« Reply #22 on: March 11, 2015, 09:19:31 AM »
#bropro
Re: MMTR Brolite
« Reply #23 on: March 11, 2015, 09:33:55 AM »
"handling package" some came with looks like
Re: MMTR Brolite
« Reply #24 on: March 13, 2015, 05:00:16 PM »
tonight's goals: remove fuel tank, patch bad spot on frame (and check for others), maybe replace rotten crossmember, mount rear axle w shackles flipped, fix brake line, consider fuel tank mounting, reinstall bed.
Re: MMTR Brolite
« Reply #25 on: March 16, 2015, 11:39:34 PM »
Frame patch finished unless I don't like something in daylight.
Next session: hang front of springs, tank and exhaust in, bed on, tighten spring bolts, flip it around in the garage and do a brake line.  Done. ?
Re: MMTR Brolite
« Reply #26 on: March 17, 2015, 11:55:33 AM »
ready for some Fox shocks yet?  i should have numbers tomorrow.  took input from decker to further tune what Erik and him are running for the build.
CJ
Re: MMTR Brolite
« Reply #27 on: March 17, 2015, 11:59:32 AM »
Once you have specs and numbers, can you send them our way? I would like to place our first order in the racer program and establish a history.
Re: MMTR Brolite
« Reply #28 on: March 17, 2015, 12:47:31 PM »
lemme know, should be no reason not to submit an order.
Re: MMTR Brolite
« Reply #29 on: March 22, 2015, 01:32:48 AM »
Out of the garage this afternoon. Frame and suspension done, exhaust done. Needs brake line and bed installed.
Flipped shackles seem really low. Maybe 5" from tube to frame with a full tank, spare tire, bumper and no bed.
