Author Topic: MMTR Brolite  (Read 94880 times)
Re: MMTR Brolite
« Reply #120 on: April 14, 2016, 08:58:47 AM »
Thought I saw a 9 somewhere. Didn’t leave the tab open though. May have been elsewhere
Re: MMTR Brolite
« Reply #121 on: April 14, 2016, 09:01:54 AM »
i will have a loose 14 at spencers tonight if you want to try one (dismounting the junk front right from the new bro)
Re: MMTR Brolite
« Reply #122 on: April 14, 2016, 05:08:57 PM »
Not sure if I'll make it over tonight or not...
I did find a pair of alloy 14x9 on fleabay for rears. If this setup works out, I'll keep an eye out for another pair of 14x9 for a second set. Otherwise I'll just go to 15s. Too much hunting.
http://www.ebay.com/itm/14x9-PRO-WHEEL-5-ON-4-5-LUG-2-/191830374819
Re: MMTR Brolite
« Reply #123 on: April 17, 2016, 10:14:06 PM »
i should have tried to get you to come over to the shop mike to see what you dont like about wills
yours will be a direct copy of the cage other than being 1.75" instead of 1.5"  it turned out nice.  i even fit in it almost.
Re: MMTR Brolite
« Reply #124 on: April 18, 2016, 12:25:57 AM »
I saw the back pillars were pushed back a bit. Seems good for interior room.
Re: MMTR Brolite
« Reply #125 on: April 18, 2016, 04:29:57 PM »
14x9s due to arrive Friday.
Re: MMTR Brolite
« Reply #126 on: April 18, 2016, 04:38:44 PM »
back pillars, rear roof bar, and X all outside of the cage- it turned out great.
rear down tubes all go to the frame, front pillars tied into cab body mounts like my truck with slight improvements
Re: MMTR Brolite
« Reply #127 on: April 26, 2016, 02:35:44 PM »
scratchpad:
need fuel cell, pump, line
need e-fan
need window net
get 1 more stock 14 and mount remaining tires
something for better bump stops espc in front
check radius arms
replumb & bleed brakes
check shock stash for what I've got travel-wise. may run edelbrock IAS that I have sitting around if they're long enough
will throw in a seat from 571
old 571 harnesses should be in the bed
have main shutoff. may have enough cable to relocate battery
need to empty bed
strip truck, probably put bed on flatbed and strip into it; haul straight to scrap.
- any attempts at selling anything from these? any luck? thinking a mint interior bits might be worth something, ditto air bags, maybe lights, and probably not glass.
I'm thinking leave factory wiring for now, mount cluster and stock column to A pillar spreader. interrupt alt charge/battery + with cutoff switch and hard wire the fan with a 40a fuse. simplest & quickest. Move battery to bed if I've got enough heavy gauge cable around to hit the starter from there.
Flip intake into cab for filter life? Need to adapt one of my cone filters to the right size or grab one.
would like to drop max weight: skin doors, front fenders, delete core support. mount 'glass bedsides, fender skins, door skins; attach grille to hood, pin the hood to the rad mount, and remove the rest.
Weld rear diff
« Last Edit: April 26, 2016, 02:37:53 PM by mr.mindless »
Re: MMTR Brolite
« Reply #128 on: April 26, 2016, 05:33:13 PM »
everything interior is junk and plastic, just rip it out and throw away
no bed and gutted cab delivered to M4 by Wednesday should be the plan for success.  Give me a night or two to get most of the cage done, then we can plasma out the front and doors, and have it ready to go minus a fuel system and shocks by saturday night.
it takes me 5 hours to gut and prep a truck
leave front windshield in until interior cage work is done (broken glass sucks!)
I have more wheels available now
Re: MMTR Brolite
« Reply #129 on: May 02, 2016, 11:11:47 AM »
scratchpad:
fuel cell:
http://www.summitracing.com/parts/sum-290112/overview/
pump:
http://www.ebay.com/itm/NEW-ELECTRIC-FUEL-PUMP-FITS-FORD-LINCOLN-MERCURY-VARIOUS-REF-E2000/221472628293?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36499%26meid%3Dd90139bbf7324b0781726610432ff32c%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D152069996559
Fuel fittings:
(3)  http://www.summitracing.com/parts/der-98201
vent bulkhead fitting:
http://www.summitracing.com/parts/vpe-16893/overview/
Need line:
http://www.summitracing.com/parts/dac-80063/overview/
Need filter:
http://www.summitracing.com/parts/frm-g3/overview/
need e-fan
need window net
http://www.summitracing.com/parts/gfr-4134bk/overview/
check radius arms
need to empty bed
Weld rear diff
Re: MMTR Brolite
« Reply #130 on: May 02, 2016, 11:33:21 AM »
Re: MMTR Brolite
« Reply #131 on: May 02, 2016, 11:35:12 AM »
i cant remember if mine is all 3/8 or 3/8 and 5/16
speed way was best for radiator and a 14" or 17" cheap fan no shroud i run
Re: MMTR Brolite
« Reply #132 on: May 02, 2016, 11:50:10 AM »
my other summit order with some stuff
radiator hoses
GTR-52425  (NLA but summit provides another number)
http://www.summitracing.com/parts/GTR-52425
GTR-52418
http://www.summitracing.com/parts/GTR-52418
gator rad hose clamps (4)
http://www.summitracing.com/parts/CCA-G31240
CCA-G31240
muffler
WLK-24215
http://www.summitracing.com/parts/WLK-24215
02bung relocate
VPE-11105
http://www.summitracing.com/parts/VPE-11105
steering cooler
FLX-3818
http://www.summitracing.com/parts/FLX-3818
fuel line or steering line clamps for 3/8 hose  (12)
CCA-G3912
http://www.summitracing.com/parts/CCA-G3912
water proof togle
PCO-5513PT
http://www.summitracing.com/parts/PCO-5513PT
water proof push button
PCO-5509PT
http://www.summitracing.com/parts/PCO-5509PT
relay kits
PCO-5591PT
http://www.summitracing.com/parts/PCO-5591PT
batt cable neg to chassis
SUM-XTP225BK
http://www.summitracing.com/parts/SUM-XTP225BK
batt cable  disco on to truck
SUM-XSS451R
http://www.summitracing.com/parts/SUM-XSS451R
batt cable- batt pos to disco
http://www.summitracing.com/parts/SUM-XTP472R
SUM-XTP472R
rad cap http://www.summitracing.com/parts/SNN-10230
SNN-10230
rad overflow  http://www.summitracing.com/parts/SUM-G1478
SUM-G1478
Re: MMTR Brolite
« Reply #133 on: May 02, 2016, 12:12:21 PM »
boom.
I probably should have clicked a button to stock up on some electrical connectors too, but I think things should be pretty well covered.
they were out of stock on 5/16 line, so only bought 3/8.
Re: MMTR Brolite
« Reply #134 on: May 02, 2016, 12:17:30 PM »
And 2 minutes after I place that order I find out that I _DO_ have to work that weekend.
Let's get her built anyway. Maybe the MA un-sanctioned race will end up the debut.
I was REALLY hoping to try and get both rigs to Rolling W so I could actually shake something down and make some shock tuning notes. I guess I'll work on it but the baseline is vacation request for 5/14 is denied.
