Author Topic: The 48' black box  (Read 82678 times)
Re: The 48' black box
« Reply #60 on: May 06, 2015, 09:27:56 AM »
i bet you are happy you checked that box you agree to FB terms
« Reply #61 on: May 06, 2015, 10:22:33 AM »
i opened the link for the heater and now all ads on facebook show ebay tankless hot water heaters.....
what ads?
adblock FTW
« Reply #62 on: May 18, 2015, 09:46:07 AM »
In the zero time i have this week id like to get my RV toilet and cold water hooked up at a minimum this week.
last night before dark i mounted the waste dump valve and scrounged up some parts from the emergency shop heater off 20lb propane tank for the cook top.  works awesome!
water pump, hoses, clamps in hand.  need to stop at lowes to grab whatever talks to a sink and toilet fixture.
« Reply #63 on: May 18, 2015, 11:46:11 AM »
Looked real good mike.
Nice set up.
Definitely keep in mind the fresh water drain for winter.
I'd run aluminum angle for all the door openings and that should take care of the wall board issues
« Reply #64 on: May 21, 2015, 12:57:51 AM »
took a hole saw to my 48' single piece roof  :-[
now have fully functioning toilet, cold water to sink, and propane cook top.  vents and plumbing finished up, 12 battery mounted, LP tank mounted.
Next phase for next trip will be hot water addition and shower installed, and walls finished.  then storage and cabinet doors ect.
« Reply #65 on: May 21, 2015, 08:08:18 AM »
Nice.
Toilet will be nice.
You'll never be able to go back now that you are entering the dark side.
« Reply #66 on: May 26, 2015, 10:26:00 AM »
ya buddy!
http://www.boarwheel.com/evron-single-19-5x6/
just found these thats like half cost of rickson for still a 5K wheel
« Reply #67 on: May 26, 2015, 10:30:38 AM »
have to call about lug / hub centric status
since i changed 4 tires on this thing this weekend, noted it has 9/16" studs, and a big hub bore that could be used for hub centric easily.
« Reply #69 on: May 26, 2015, 10:53:52 AM »
225/70R19.5 = 31.9X8.86R19.5
Diameter = 31.9"Width = 8.86"Wheel = 19.5"Sidewall = 6.2"Circumference = 100.2"Revs/Mile = 632.5
235/80R16 = 30.8X9.25R16
Diameter = 30.8"Width = 9.25"Wheel = 16"Sidewall = 7.4"Circumference = 96.7"Revs/Mile = 655.1
« Reply #70 on: May 26, 2015, 01:57:19 PM »
9/16 studs ftw.
Found when buying my replacement caliper that my disk hubs could be had with 9/16 studs as well as the 1/2 I bought. Sad fail.
« Reply #71 on: May 26, 2015, 05:46:16 PM »
just called the wheel place, the 19.5 singles are lug centric with a 60 degree cone machined in them-  guy actually picked up phone new everything i needed to know lol
« Reply #72 on: June 02, 2015, 11:46:16 AM »
rolling on dumpster tires this weekend!  whoooooo!
« Reply #73 on: June 02, 2015, 12:22:03 PM »
getting back to your roots!
« Reply #74 on: June 08, 2015, 02:11:28 PM »
no tires issues this weekend rolling with one car.  have too look at fuel receipts but looks like 9mpg at 66mph
19.5 wheels ordered, just confirmed shipment via phone.  should be Fedex freight later this week.  plan to service bearings with wheel swap.
man it is nice with running water and a flushing toilet!  cook top works great to!  i have used like 2" of water in my 40 gallon tank that was half full.  going to try and finish the hot water, shower, and walls for IN trip, but might be a stretch.
