Author Topic: The 48' black box  (Read 72486 times)
Re: The 48' black box
« Reply #45 on: April 17, 2015, 07:39:17 AM »
MDF doesn't typically have the same expansion and contraction characteristics that wood has.
What are you attaching the sheets to? Wood studs or Steel trailer studs? If it's attached to wood studs  it could be an issue of the studs drying out?
Would really need to see it.
I used the same product in my motorcycle race trailer when I finished out the living quaters.
Don't remember any issues screwing to both wood and steel studs throughout the different seasons.
« Reply #46 on: April 17, 2015, 09:52:19 AM »
its wood studs.
expansion is like 1/2" in 3 places over 4', i doubt the studs moved that much.  the aluminum counter top i glued on is fine also.
« Reply #47 on: April 17, 2015, 10:37:27 AM »
Strange.
Hard to speculate with out seeing it.
« Reply #48 on: May 04, 2015, 01:39:14 PM »
brolite and buggy fit snug and hauls nice.
need to finish plumbing and bath.  was super nice having a counter and cook top area.  going to work great!
« Reply #49 on: May 04, 2015, 02:11:50 PM »
nice setup fo sho!
« Reply #50 on: May 04, 2015, 02:30:12 PM »
lost left blinker from half trip there and back.  same side KOH trip blew fuse.  fuse checked good.
unsure of cause.  will check out when pig tail gets changed and longer.
« Reply #53 on: May 05, 2015, 04:32:03 PM »
More parts on the way.
(2) roof vents, smoked covers
(2) 24"x22" slider tinted windows with screens and trim rings
LPG on demand hot water heater, with external exhaust, fully automatic and Dbattery ignition
14' trailer light pigtail cord
trailer light plug in truck check tool
« Last Edit: May 05, 2015, 04:35:12 PM by M4wdFab »
« Reply #54 on: May 05, 2015, 05:46:21 PM »
That sounds very cool!
Would be interested in details, the 5gal in the popup failed pressure test. Not sure where it popped, but it’s toast somewhere.
« Reply #55 on: May 05, 2015, 06:47:15 PM »
i was down to two in my cart.  opted for the more spendy one that had a 5yr warranty, no shut of timer, and a flow switch as opposed to a pressure switch for htr enable.
http://www.ebay.com/itm/261845674876
i got the smaller unit than gif i believe
« Reply #56 on: May 05, 2015, 07:05:33 PM »
Thanks. Seems cool, not sure I have the height in the popup. I’ll have to check it out.
« Reply #57 on: May 06, 2015, 12:51:25 AM »
didnt know the popup had a shower / need for hot water
« Reply #58 on: May 06, 2015, 08:37:20 AM »
Would be nice for sink. Also Has an outdoor shower already set up on the front corner.
« Reply #59 on: May 06, 2015, 09:03:20 AM »
i opened the link for the heater and now all ads on facebook show ebay tankless hot water heaters.....
