Author Topic: F350 knuckle swap  (Read 56413 times)
F350 knuckle swap
« on: March 10, 2012, 05:54:09 PM »
I had a brake issue today so the trigger is pulled on this. D60 is in the bed, brake parts ball joints and ujoints requested from our preferred provider.
I need to have the hub lip turned down from 4.88 to 4.77. Should be a cake job; is that m4wd government project possible or do I need to run down to OEM again?
Hmm, If I was smart I'd get bearrings and seals ahead of time too wouldn't I?
Re: F350 knuckle swap
« Reply #1 on: March 10, 2012, 07:30:29 PM »
You have till Monday to compile a list...
I'll do first thing Monday morning when I get in.... Assuming flights are on time..
« Reply #2 on: March 10, 2012, 07:39:33 PM »
F350 knuckle swap
« Reply #3 on: March 10, 2012, 08:46:33 PM »
Somehow it just fits this thread haha
F350 knuckle swap
« Reply #4 on: March 11, 2012, 12:48:10 AM »
Sent you two emails. Didn't think of anything else... quite yet :)
F350 knuckle swap
« Reply #5 on: March 11, 2012, 12:51:11 AM »
I'll need to reread a couple things to know if I'll need any steering parts. I really don't remember on that.
Eric at EMS showed me that '09+ steering is a nice bolt on upgrade to our trucks though. Its as much of an upgrade as v8 zj stuff is on a tj, and it's better geometry too. Inverted T instead of inverted Y, and the link goes in the top so it doesn't give the dead spot roll. Clever...
« Reply #6 on: March 11, 2012, 10:16:54 AM »
You are thinking zj or tj to wj upgrade weirdo!
F350 knuckle swap
« Reply #7 on: March 11, 2012, 02:48:05 PM »
I thought it was v8 zj??
« Reply #8 on: March 11, 2012, 07:55:56 PM »
"our trucks" are different!
F350 knuckle swap
« Reply #9 on: March 11, 2012, 08:04:49 PM »
That's right, the AAM front end swapped steering too didn't it?
F350 knuckle swap
« Reply #10 on: March 11, 2012, 08:09:24 PM »
I should remember this from pasts pile raiding.
« Reply #11 on: March 11, 2012, 08:09:52 PM »
something was different!
must be the higher load capacity of the AAM!
F350 knuckle swap
« Reply #12 on: March 11, 2012, 08:20:26 PM »
Speaking of axles remind me to share his opinion on the 14b. Pretty interesting.
« Reply #13 on: March 11, 2012, 08:27:51 PM »
F350 knuckle swap
« Reply #14 on: March 11, 2012, 08:34:48 PM »
Fucking cat!
Think you can do hubs, mike?
