Author Topic: Brandy new 4500 Cummins  (Read 250983 times)
Re: Brandy new 4500 Cummins
« Reply #75 on: October 12, 2014, 11:18:52 PM »
I wonder if it's an option to try first by ask the dealer if they can reprogram on your truck with a program that's used in 2014 Ram 3500 with AISIN auto trans? If I recall correctly on some forums some guys with the manual, they had dealer to reprogram them to bring the power level up to what's found in trucks with the AISIN trans.
2014 Ram 3500 with AISIN     385 hp, 850 ft-tq
2014 Ram 4500 with manual  320 hp, 650 ft-tq
2014 Ram 4500 with AISIN       325 hp, 750 ft-tq
If the dealer will do that for you, that'll pretty much means a 65 hp, 200 ft-tq increase for you!
Just an idea if it'll work to have the dealer to reprogram your truck and not void the warranty and possibly cheaper, or free if you can talk haha.
« Last Edit: October 13, 2014, 03:57:38 PM by TrailTamer »
« Reply #76 on: October 12, 2014, 11:21:11 PM »
probably do this one
http://www.xtremediesel.com/edge-products-31006-juice-with-attitude-cs-monitor.aspx
gona research DEF delete stuff too, but not excited about turning wrenches on my new truck.  rather just plug and p(l)ay
« Reply #77 on: October 12, 2014, 11:26:31 PM »
When I was riding with you, I noticed that interesting how it's max boost typically around 19 psi, spikes to 20-21psi sometime. It's just that it don't sounds much. I routinely hit 40 psi of boost in my truck, if I really want to push, I can get 50 psi out of mine, I'm sure it don't like it haha.
wnyjpgy
« Reply #78 on: October 13, 2014, 08:12:22 AM »
Smike,
Do a search on "torque management", the new 12 cummins I had with the G56 had the same feeling that your going through.
Ram basically has some software that de-tunes the engine (boost and whatever else) to keep the trans and clutch alive since they are only rated for 650 ft/lbs.
Most programmers are able to deactivate it, but I just wanted to make you aware of it before your tuner purchase.
The silver 12 Cummins truck I had was a 800 ft/lbs truck and it ran and pulled pretty decent.
I still like the 01 cummins I sold you, and if I bought another it would be a 01-07 with a manual.
On a side note I've been towing the JK with a A class motorhome I bought earlier this summer.
« Reply #79 on: October 13, 2014, 09:56:34 AM »
Chassis Cab   2010–present   5.7 L (345 cu in) Hemi V8 (3500 Only)                                       383 hp (286 kW)   400 lb·ft (540 N·m)
                        2010–2012   6.7 L (408 cu in)Cummins diesel I6                                       305 hp (227 kW)   610 lb·ft (830 N·m)
                        2013–           6.7 L (408 cu in)Cummins diesel I6  (6-Speed Manual)               320 hp (240 kW)   650 lb·ft (880 N·m)
                        2013–           6.7 L (408 cu in)Cummins diesel I6 (Aisin AS69RC Automatic)   325 hp (242 kW)   750 lb·ft (1,020 N·m)
« Reply #80 on: October 13, 2014, 01:17:24 PM »
Arie, how much is a 55 gal drum of def by the way?
« Reply #81 on: October 13, 2014, 01:24:51 PM »
 Flying J I-90 Exit 48A Pembroke NY, US $2.899 / gal  8 lanes with bulk pumps
« Reply #83 on: October 13, 2014, 04:22:12 PM »
RAM4500  9940lbs
RAM2500  7500lbs
572           4700lbs
wedge       5500lbs
« Reply #84 on: October 13, 2014, 04:50:04 PM »
« Reply #85 on: October 13, 2014, 04:56:19 PM »
interesting.  i hadent thought of that.
looks like the bulk supply pumps on the way to see my mom once in a while will do it
« Reply #86 on: October 13, 2014, 04:59:23 PM »
i guess walmart stocks a 2.5 gal jug for 12$
i have a 9 gallon tank bah
« Reply #87 on: October 13, 2014, 05:48:48 PM »
Kinda surprised you went through that much def. That's borderline medium duty usage. I'll usually get 7-8000 per 2.5 gallon jug. Towing it'll drop to 4-5000.
« Reply #88 on: October 13, 2014, 07:39:35 PM »
I think there is alot of saftey in the gage.  Just put in 5 gals and it went from below zero to past 100%.  Threw another jug in tool box.
« Reply #89 on: October 14, 2014, 09:44:22 AM »
Nick says his truck runs 30psi boost and its the 800 FT LB auto version, must be a 2013?  9.5mpg at 23K lbs
he runs the juice tuner, and said it didnt do much for the truck.  We are going to try his tuner on my truck
