Author Topic: Gif Built Buggy  (Read 98350 times)
Re: Gif Built Buggy
« Reply #60 on: August 23, 2012, 10:26:57 PM »
is there anything better than bonding steel with electricity? :)
Re: Gif Built Buggy
« Reply #61 on: September 07, 2012, 08:01:06 AM »
Belly complete.
Almost all back together.
Re: Gif Built Buggy
« Reply #62 on: September 07, 2012, 08:07:09 AM »
Got her running last night.    :)
Punch list:
1) front drive shaft
2) Engine skid
3) seats
4) skins
5) drive into trailer
orange anchor
Re: Gif Built Buggy
« Reply #63 on: September 07, 2012, 08:34:51 AM »
lets go wheeling
Re: Gif Built Buggy
« Reply #64 on: September 07, 2012, 08:36:36 AM »
looking good.
couple of us are heading to Whispering pines sunday if your interested for shake down!
Re: Gif Built Buggy
« Reply #65 on: September 08, 2012, 06:30:26 PM »
This pig is ready for another beat down!
Re: Gif Built Buggy
« Reply #66 on: September 17, 2012, 06:33:23 PM »
new belly and skid worked great.   was a nice feeling knowing i could bash rocks and not hurt it. ;D
Broke the front drive shaft 1 hour into the first day. boo.   but some thin wheel work and parking lot welding and she was good to go for the rest of the weekend. thanks to smike for the use of his welder.
Rear axle hub seal leaks now.
Front pass side upper link mount took a beating, still works, but not pretty anymore...
change/top off some fluids and shes good to go.
I think on board air is next for this pig.
Re: Gif Built Buggy
« Reply #67 on: December 17, 2012, 04:45:36 PM »
Working on some OBA.
York 210 AC with twin V belt clutch.
I spun a serpentine off a power steering pulley and then spun down the v belt pulley
pressed the serp on and welded it.
Gif Built Buggy
« Reply #68 on: December 17, 2012, 08:46:17 PM »
Nice conversion. Gives me a new thought for the Dumpbus instead of mating a pulley and running a secondary V belt like I did on the Dakota.
Re: Gif Built Buggy
« Reply #69 on: December 17, 2012, 08:50:21 PM »
I need some good cutting tools for my lathe. Where do you get quality tooling?
Re: Gif Built Buggy
« Reply #70 on: December 18, 2012, 10:01:13 PM »
Cut the factory AC bracket to make room for the York.
Then made up a new mount bracket.  Still need to make up the top side of the bracket.
Also need a small brace on the bottom side.
Gif Built Buggy
« Reply #71 on: December 18, 2012, 11:12:05 PM »
Does the separate crack case still have the same advantage when run on its side?
Re: Gif Built Buggy
« Reply #72 on: December 19, 2012, 12:09:44 AM »
i have an extra bracket for you, and another on the tbi motor i pulled from the buggy
Re: Gif Built Buggy
« Reply #73 on: December 22, 2012, 09:30:42 PM »
Home made pulley did not fit. :(        OD was 6-1/4"    Ordered a new one 5-7/8"    $65
Its a tight fit under the hood.
Re: Gif Built Buggy
« Reply #74 on: December 22, 2012, 09:42:04 PM »
Finished the top bracket.  Now the York is captured with 6 bolts.
New Serp belt @ 100.5"     FYI   P/N  5061005    50=Belt    6=6groove  1005=100.5"
