Author Topic: Gif Built Buggy  (Read 98345 times)
Re: Gif Built Buggy
« Reply #45 on: July 02, 2012, 04:28:36 PM »
So here is my engine tic.
should look like this:
Gif Built Buggy
« Reply #46 on: July 02, 2012, 05:32:16 PM »
Horay for actual good news
Re: Gif Built Buggy
« Reply #47 on: July 02, 2012, 06:32:40 PM »
Now I just need to figure out my low oil pressure.
Re: Gif Built Buggy
« Reply #48 on: July 05, 2012, 11:55:23 AM »
Bent Skid plate
« Last Edit: July 05, 2012, 11:59:14 AM by gif »
Re: Gif Built Buggy
« Reply #49 on: July 17, 2012, 01:15:49 PM »
So,  low oil pressure is from cam bearings that got hammered.
Theory is that I had too much oil in the pan and the crank was splashing into a froth.
Aerated oil is not good for an IC engine.
Re: Gif Built Buggy
« Reply #50 on: July 18, 2012, 12:27:41 AM »
i call bs on too much oil   i run at least 2 quarts over any motor i race   haha
Re: Gif Built Buggy
« Reply #51 on: August 20, 2012, 03:01:38 PM »
Buggy is sad.
I removed the engine for repairs and cut out ALL of the subframe and skidplate.
I got the engine back with new cam bearings and started mocking the new subframe.  2x2x.25" wall box tube with .25" skid plate. I'm going for beef,  screw light weight...
I also changed the tranny mount so that its not part of the lower subframe.
I hope to have this thing ready for Big Dogs.
Re: Gif Built Buggy
« Reply #52 on: August 20, 2012, 03:13:17 PM »
you put your link bolts not straight again, wont the geometry bind up like the first iteration of the rear before?
Re: Gif Built Buggy
« Reply #53 on: August 20, 2012, 03:29:41 PM »
If I was bushings,  yes.
Re: Gif Built Buggy
« Reply #54 on: August 20, 2012, 04:16:04 PM »
o, swaping out those bushings i see for heims?
Re: Gif Built Buggy
« Reply #55 on: August 20, 2012, 06:17:42 PM »
the lower links front and rear frame side were/are ballistic weld on joints
Re: Gif Built Buggy
« Reply #56 on: August 22, 2012, 03:37:17 PM »
I figure I have 1 or 2 more nights of fab before I can burn in the new steel.
Then it will be time for final assembly (again).  ::)
Installing the engine and tranny is like a bar puzzle now.
Re: Gif Built Buggy
« Reply #57 on: August 23, 2012, 08:15:53 AM »
Subframe complete.
Most of the little mods are done to allow for the new chassis.
Transfercase comes out the top now.  I made the scatter shield removeable.
also built a type of tranny mount "sling" to keep everything off the subframe/skidplate.
Re: Gif Built Buggy
« Reply #58 on: August 23, 2012, 08:55:54 AM »
gona have to go up in spring rate for all that 2x2 haha
Re: Gif Built Buggy
« Reply #59 on: August 23, 2012, 09:15:45 AM »
Quoted for truth.
