Author Topic: 571  (Read 264535 times)
Re: 571
« Reply #525 on: May 26, 2015, 06:11:53 PM »
I’m not tagged in anything less recent than new paint that I can see the bumps.
Had to have been missing since I’ve had it. Lucky I guess?
Re: 571
« Reply #526 on: May 26, 2015, 06:27:31 PM »
I'd be ok skipping the meeting also
CJ
Re: 571
« Reply #527 on: May 26, 2015, 07:11:55 PM »
Where is the meeting?
Re: 571
« Reply #528 on: May 26, 2015, 08:05:21 PM »
The Moose lodge
Re: 571
« Reply #529 on: May 27, 2015, 12:05:53 AM »
if you didnt get an email, up date your profile
spun down two new 1" thread bungs for rear upper replacement
Re: 571
« Reply #530 on: May 29, 2015, 10:58:35 AM »
should be a finishing machine!
Re: 571
« Reply #531 on: May 29, 2015, 11:36:07 AM »
Some very reasonable upgrades completed on this unit thanks to the crack team at M4wd!
Alignment completed.
Front bump stops set & fixed - no more bottoming and breaking things.
Rear height bumped up to ~6" shaft showing, and broken shock swapped. Still no parts from our friends at Profender, so another NEW shock on the car.
Rear upper links vastly improved with fresh heim joints instead of waiting-to-break welded shank Johnny Joints
Stretched shock eye swapped
Beat bump pad swapped
Needs:
right kingpin preload bolt replaced. snapped while adjusting
steering hose replaced - nicked by overcompressing frontend
Limit straps mounted (longer rear, adding fronts) - calling PRP shortly to check on shipping, since they said they were going out yesterday but didn't actually get on the brown truck according to tracking
Siren installed (eta sometime next week)
Rear-rear ujoint checked, some cross play. maybe worn or maybe stretched 14b yoke
double check all bolts, etc.
Next:
rear bumps
front driveshaft
aluminum links, hiems everywhere, 5/8 & 3/4 hardware everywhere. no more 9/16.
2.5s
rear swaybar
rewire
motor? (oil smoke not gone...)
Re: 571
« Reply #532 on: May 29, 2015, 12:21:50 PM »
Finally got my shock body ::)
Re: 571
« Reply #533 on: May 29, 2015, 12:25:33 PM »
lol that sucks
Re: 571
« Reply #534 on: May 29, 2015, 12:31:46 PM »
The fail is strong with Mike and Dean :(
PRP limit straps due tuesday. All well there - mixed up with another order. Too many things are on the way.
Re: 571
« Reply #535 on: May 29, 2015, 03:50:15 PM »
I think that Whalen external speaker is still in my trunk...  :-[
Re: 571
« Reply #536 on: May 29, 2015, 04:09:39 PM »
That's okay...
We'll see how this Pelican 200w unit fares. I'm sure it's plenty of loud, durability in the environment will be the question...
Re: 571
« Reply #537 on: June 01, 2015, 10:04:42 AM »
Limit straps and siren both due tomorrow.
Looking at rear-rear ujoint today. Bought 3/4" fine thread gr8 bolts this morning to replace artec preload set screws since one broke.
Steering lines replaced yesterday and system bled. Powerdrives had a sweet adaptor to 45Ëš flare to get rid of that kinked stock PS line into compression fitting out of the pump, looks good.
Should have the car at 100% by tomorrow end of day. Then have some patch & paint to do on the outside of Kim's house and should have that place pretty much squared away before we leave for the race, too. Another long week in the making!
Re: 571
« Reply #538 on: June 01, 2015, 12:56:55 PM »
ya we use those fittings, they are called "bump fittings" by the old guy at power drives
Re: 571
« Reply #539 on: June 02, 2015, 03:04:20 PM »
Going to need to figure out a waterproof box for this guy, and how to wire to a single speaker. No instruction Chinese unit...
Speaker is a 2 wire connection.
Need to find room for the speaker too! Big Mohambe.
