Author Topic: 571  (Read 264765 times)
Re: 571
« Reply #285 on: July 15, 2014, 05:05:42 PM »
Sweetness
I'm avail to lend a hand after work if u need one.
« Reply #286 on: July 16, 2014, 08:03:08 AM »
R&L just called. Delivery between 11-15:00 tmw.
I guess I'll be doing a little work from home.
Dinner plans tomorrow evening. Gonna wrap up the car Friday daytime but I really appreciate the offer!
« Last Edit: July 16, 2014, 08:04:44 AM by mr.mindless »
Re: 571
« Reply #287 on: July 16, 2014, 11:12:49 PM »
Hope this floor turns out. What a fuck ton of work to get it done how I want.
Re: 571
« Reply #288 on: July 17, 2014, 08:47:34 AM »
Floor turned out. Was a fuckton of work, but it's done and done right. Seat mounts redone quick release style. They come out in one minute apiece with side tins off and should go in in under 5 with no air tools. Case in. Shafts hooked back up. Parts of floor final installed.
Potential for 2-3 hour trans swap. Probably 2 with a helper, 3 solo with a cherry picker. Injury solo without a cherry picker.
Musts:
Trans and sundries. Flush coolers.
Tcase shifters (or not)
Lap and sub belts
Reinstall center console and switches
Window net bar if a codriver magically appears. I don't think I have parts for that.
Water leak (went away after a day but was bad for that day. Weird). Plug heater hose holes.
Want to:
Swap squeaky alt
Do a little more mounting and splash protection on the new gauges.
Grease front axle ujoints
Check gear lube
Mount 6th tire and clearance rim, check pressures, remove wood from bead in RR.
Smike said something about number plates. I'll forget that.
Re: 571
« Reply #289 on: July 17, 2014, 09:08:28 AM »
I never would have come close to finishing a 700r4 swap, by the way. Nowhere near.
I flash burned my left arm really badly. It's been ages since I've causally fabbed like this. Sad!
Re: 571
« Reply #290 on: July 17, 2014, 10:00:50 AM »
no water leak because the top of the block emptied
pull the water pump is 2nd high on the list after the trans!
Re: 571
« Reply #291 on: July 17, 2014, 03:35:59 PM »
And I just damn near hit a deer coming onto campus on my way back from nu way
Re: 571
« Reply #292 on: July 17, 2014, 03:40:33 PM »
you going to be slaving all night?
Re: 571
« Reply #293 on: July 17, 2014, 03:51:30 PM »
That was last night. I'll probably do a 9- midnight stint and wrap tomorrow day.
Re: 571
« Reply #294 on: July 17, 2014, 04:25:22 PM »
looks like a business dock delivery to me!
Re: 571
« Reply #295 on: July 18, 2014, 03:08:22 AM »
Took forever to get the new trans ready. Tail shaft has different threads for the speedo hold down, I had to dig out a fine thread bolt. Lots of shut to swap over. Cleaning the pan out took a while and a full can of brake clean with those cooling tubes running through it.
I'm going to drive this like a full manual this weekend but it isn't really. It has a kickdown cable (that I had to seal up and block off) and functional vacuum modulator (capped off). Quick reads told me that the vacuum modulator is what controls part throttle up shifts, but is too dumb to do the downshifting at low vacuum and high load, hence the kickdown cable. This vac modulator is upgraded to an adjustable unit.
I'm going to go ahead and hook that shit up. If I could get the trans to work well in drive, that's one less thing to think about, and there's no reason it shouldn't be able to.
I have the trans in the chassis but not all the way home. Still have to flush coolers, install belts & a seat, console and wire switches, window net, and water pump. I'm not going to bother with tcase shifters and I'm sure a few other things will get skipped. If I could teleport to PA and get to Shamokin early enough I would hit AOAA for a shakedown lap, but odds on that are absolutely zero with travel taking time. Oh well.
Going to do a bit more reading now to see if I need to extend the kickdown cable and lock it there to avoid doing harm. I hope not, I don't have a great way of doing that.
Re: 571
« Reply #296 on: July 18, 2014, 08:29:37 AM »
how did the trans mount bolts line up- did you tap them out to 1/2"?
sounds like my cluster of cutting and welding a chassis nut 2x
Re: 571
« Reply #297 on: July 18, 2014, 09:57:53 AM »
I looked around on google and many said the kickdown cable removed/disabled will not hurt it but TCI said it should be installed anyhow. I'll do what TCI says as they're the one who built it and to keep the warranty.
http://www.tciauto.com/tc/automatic-transmission-dos-donts
Otherwise give TCI a call and see what they recommend in your specified situation.
Re: 571
« Reply #298 on: July 18, 2014, 10:14:26 AM »
warranty?  haha
Re: 571
« Reply #299 on: July 18, 2014, 10:50:21 AM »
If there are!
