Author Topic: Willys MB build  (Read 196228 times)
tony
  • Come and take it
Re: Willys MB build
« Reply #450 on: December 14, 2015, 10:08:11 PM »
Looks good
Sent from my SM-G928V using Tapatalk
Re: Willys MB build
« Reply #451 on: December 17, 2015, 05:36:19 PM »
New Y-link made
and now officially a 'roller'
Re: Willys MB build
« Reply #452 on: December 18, 2015, 05:32:18 PM »
exhaust work today
tight-radius turn downs cut and welded in
rough placement over rear axle
jacel861
  • Full Member
Re: Willys MB build
« Reply #453 on: December 18, 2015, 05:49:06 PM »
Aww yeahhh! Detail time :-)
Re: Willys MB build
« Reply #454 on: December 29, 2015, 05:03:30 PM »
Radiator and grille mounting done
Re: Willys MB build
« Reply #455 on: December 29, 2015, 05:40:34 PM »
Looking nice
jacel861
  • Full Member
Re: Willys MB build
« Reply #456 on: December 29, 2015, 06:10:40 PM »
Is that orange the final color?!?!
Re: Willys MB build
« Reply #457 on: December 29, 2015, 06:26:57 PM »
Yes, for tins.   ;D
jacel861
  • Full Member
Re: Willys MB build
« Reply #458 on: December 29, 2015, 08:16:36 PM »
I like! :-D
Re: Willys MB build
« Reply #459 on: December 30, 2015, 06:21:20 PM »
awesome  :D
looks great
Re: Willys MB build
« Reply #460 on: December 31, 2015, 06:18:27 PM »
Fun with exhaust tubing today
Re: Willys MB build
« Reply #461 on: January 01, 2016, 12:10:41 AM »
splurge for stainless misalignment if you ever plan on pulling those bolts without cutting them.  or maybe some anti seize would do it.  we have had terrible luck on matts car and most had to be cut out.
Re: Willys MB build
« Reply #462 on: January 01, 2016, 09:46:38 AM »
Thanks for the tip!  Didn't think I would need anything since not seeing NY salt.  Anti-sieze worked on the Rubicon; I'll try that.
Re: Willys MB build
« Reply #463 on: January 30, 2016, 04:16:39 PM »
I used exhaust band clamps a lot. They're not exactly reusable. I usually impact them down until there's no gap. I remember the packaging says to torque them to spec but it's way too low IMHO. I cut them off to disassembly. I'll not go back to the crummy u-bolt clamps again.
Re: Willys MB build
« Reply #464 on: January 30, 2016, 08:29:17 PM »
Two band clamps per side.  One middle split butt joint and one lap joint at muffler.  Seems pretty solid.
ps: there are different designs of band clamps and the one you pictured is one of the better designs.
