Author Topic: Willys MB build  (Read 195955 times)
Re: Willys MB build
« Reply #465 on: January 30, 2016, 08:52:56 PM »
Been a while since last update.  Lots of stuff being tackled:
Brake booster rod fabbed and adjusted
Brake pedal arm shortened and mounted
Orbital mounted, steering shaft and u-joints fitted, tilt column and wheel mounted
Exhaust finished except one band clamp, O2 sensors installed
Re: Willys MB build
« Reply #466 on: January 30, 2016, 09:24:11 PM »
Gonna be ready for Big Dogs?
Looks really nice.
Re: Willys MB build
« Reply #467 on: February 07, 2016, 01:14:29 PM »
Much progress! Looking good!!
Re: Willys MB build
« Reply #468 on: February 14, 2016, 06:32:38 PM »
Front bumps done
Front third member returned from ARB install
...and front and rear third members set into the housing with LubeLockers
All front heim bolts given a coating of anti-seize compound.
Axle housing breathers drilled and prepped.
Axle shafts ordered through ECGS.
Re: Willys MB build
« Reply #469 on: February 14, 2016, 06:50:47 PM »
fuel pump, order 2
http://www.ebay.com/itm/NEW-ELECTRIC-FUEL-PUMP-FITS-FORD-LINCOLN-MERCURY-VARIOUS-REF-E2000-/221472628293?hash=item3390cc1e45:g:388AAOSw5IJWgOdS&vxp=mtr
this is the disconnect Matt and I run after blowing some of the lower $$ discos
http://www.summitracing.com/parts/mor-74102/overview/
I run the metal HF one in the brolite thats only 9$
Re: Willys MB build
« Reply #470 on: February 14, 2016, 06:51:23 PM »
I still think those shocks are going to be a bit rough ;-)
Re: Willys MB build
« Reply #471 on: February 14, 2016, 07:14:57 PM »
Thank you, sMike!
Jared, I'll just lower the tire pressure?!
Re: Willys MB build
« Reply #472 on: February 27, 2016, 08:03:41 PM »
This week's arrivals from ECGS
« Last Edit: February 29, 2016, 08:21:09 AM by Wingman »
wnyjpgy
Re: Willys MB build
« Reply #474 on: February 29, 2016, 07:13:32 AM »
Do you know hat angles your rear arms are at? Just curious, I mocked mime up over the weekend.
Are your lowers parallel, or angled out to the wheel? I think I'm going to be about 10 degrees out on each of my lowers...
Once again, just trying to learn.
Re: Willys MB build
« Reply #475 on: February 29, 2016, 07:55:58 AM »
They are nearly parallel with the frame rails, <5* by eyeball measure.  In my case, it was more about packaging than anything else.
Optimally, it should be double triangulated or as close to it.
Re: Willys MB build
« Reply #476 on: February 29, 2016, 10:55:57 AM »
When you'll be ready for my help with engine harness?  ;D
Re: Willys MB build
« Reply #477 on: March 01, 2016, 10:07:44 AM »
Two years since this project began...  :o
Re: Willys MB build
« Reply #478 on: March 01, 2016, 10:54:17 AM »
And you're retired.   Slacker!
Re: Willys MB build
« Reply #479 on: March 03, 2016, 09:05:14 PM »
