Willys MB build
Pages:
37
38
39
40
53
Topic: Willys MB build (Read 195981 times)
Re: Willys MB build
Reply #555 on:
June 04, 2016, 10:50:43 PM »
Must be getting close now.
Friendly Competitor
Friendly Competitor!
Re: Willys MB build
Reply #556 on:
June 06, 2016, 01:19:27 PM »
Yea man!
wnyjpgy
Sr. Member
Re: Willys MB build
Reply #557 on:
June 06, 2016, 03:51:59 PM »
Mark, My TJ is almost done as well... You plan on hitting Rausch for Eugene's benefit or WeRock?
We have similar sized rigs, it would be nice to get together instead of always just run into each other on the trail.
Free Loader
Re: Willys MB build
Reply #558 on:
June 06, 2016, 04:17:24 PM »
As you likely saw on the Events thread, hopeful shakedown run July 4th...
Free Loader
Re: Willys MB build
Reply #559 on:
June 07, 2016, 03:44:02 PM »
Got one new spindle bearing delivered, installed on passenger side, and reassembled the hub. Found the inner shaft yoke had clearance issues with the inner C.
Contacted ECGS and got approval to take a little material off of the yokes. All good.
Free Loader
Re: Willys MB build
Reply #560 on:
June 07, 2016, 08:09:02 PM »
Also learned that there is a year split for oil filters on the Corvette C6 oil pan. 2005-6 LS2 pan uses ACDelco P46E or equivalent and the 2007-9 LS2 & LS3 uses ACDelco PF48E. Took me four attempts to get it right. Bah!
Free Loader
Re: Willys MB build
Reply #561 on:
June 10, 2016, 08:14:22 PM »
Arie sourced these awesome Cardone Ultra calipers. Powder coated metallic silver, includes banjo bolt & crush washers, the works! I'm impressed at the quality.
Engine bay wiring nearly complete. Used the old battery wiring harness for alternator and starter runs and put the battery terminal end to a junction block on the firewall. Pulled switch panel power from there too. Ran 1/0 from the junction block to the battery that will be located in the rear.
Free Loader
Re: Willys MB build
Reply #562 on:
June 11, 2016, 04:45:12 PM »
Inner spindle/axle bearings replaced as a precaution. Didn't want the 4340 stub shafts getting chewed up. Front axle now an official drive axle too.
OEM battery ground cable cut and lugs soldered on for engine/frame grounding.
Re: Willys MB build
Reply #563 on:
June 27, 2016, 09:20:09 AM »
gona make it mark?!
Free Loader
Re: Willys MB build
Reply #564 on:
June 27, 2016, 09:27:08 AM »
Fingers crossed. Couple of hiccups along the way. Punch list getting shorter.
Please stand by......................
Re: Willys MB build
Reply #565 on:
June 27, 2016, 09:51:21 AM »
The 5.3 runs yet???
Re: Willys MB build
Reply #566 on:
July 03, 2016, 01:02:02 PM »
This thing is a work of art!
Hannah
Full Member
Re: Willys MB build
Reply #567 on:
July 06, 2016, 11:51:36 PM »
just a few from this past weekend
Hannah
Full Member
Re: Willys MB build
Reply #568 on:
July 07, 2016, 12:04:36 AM »
a few more...
Hannah
Full Member
Re: Willys MB build
Reply #569 on:
July 07, 2016, 12:09:22 AM »
Pages:
37
38
39
40
53
Willys MB build
