Author Topic: Willys MB build  (Read 195981 times)
Re: Willys MB build
« Reply #525 on: April 11, 2016, 04:42:03 PM »
They are awesome and will do a custom top in any color. Or maybe american flag???
We have become pretty close with them so let us know if you decide to go that route.
Only drawback to Spiderweb shade... they don't make solid cover. Only perforated.
Re: Willys MB build
« Reply #526 on: April 11, 2016, 05:51:13 PM »
Will that net me a sweet speckled sunburn pattern on my bald melon?
Re: Willys MB build
« Reply #527 on: April 11, 2016, 08:13:58 PM »
Nope No sunburn. Scandinavian bald head tested.
Re: Willys MB build
« Reply #528 on: April 11, 2016, 09:25:39 PM »
Accel pedal mounted
Wiring harness pinout started
Re: Willys MB build
« Reply #529 on: April 13, 2016, 07:57:32 PM »
I've been stumped with this connector on my harness.  It appears to be an engine to chassis connector (AC Delco #PT2389) with provisions for ignition, gauges, and AC, CC control connections, etc.  I've been all over the inter webs with no success.  If anyone recognizes it and can provide a pin-out, I'd be grateful.
Doesn't this look FUN?!  I performed the pin-out on the ECM in an effort to vet the mystery connector.  I have all wires identified except one that goes into the harness, not the ECM.  It has 3 wires and terminates near the crank pulley with no sensors nearby.
Not terribly concerned since all sensors seemed to be accounted for...
Re: Willys MB build
« Reply #530 on: April 15, 2016, 09:51:06 AM »
Any luck?
Re: Willys MB build
« Reply #531 on: April 15, 2016, 11:59:58 AM »
skip all that
pink wires and orange wires power, kick starter, tune computer, go    ;D
Re: Willys MB build
« Reply #532 on: April 15, 2016, 05:37:05 PM »
Still no info on the wire or connector. Going to ignore it.
Re: Willys MB build
« Reply #533 on: April 18, 2016, 08:34:49 AM »
skip all that
Re: Willys MB build
« Reply #534 on: April 20, 2016, 09:04:29 PM »
Harness nearly buttoned up, need to assemble relay pack.
skip all that
Would not have worked with this harness...  :-\
Re: Willys MB build
« Reply #535 on: April 21, 2016, 02:19:49 AM »
lies
Re: Willys MB build
« Reply #536 on: May 27, 2016, 09:29:52 PM »
Thread rolled off Projects first page, time to get to work.
Installed the custom shafts in the rear housing.  Slid in past the inner spindle bearing without issue and fit perfectly.  It is officially a functional drive axle.
Ordered driveshafts from Hi-Angle Driveline.  Had to choose between road-ability with limit strap or 2x cost and max angle.  Road-ability won.  ~2 weeks out.
All(?) brake supplies arrived.  Time to bend little toob.
Re: Willys MB build
« Reply #537 on: May 28, 2016, 07:23:07 PM »
NiCu FTW!
Re: Willys MB build
« Reply #538 on: May 30, 2016, 07:09:38 PM »
Need to come up with a non zip-tie solution...
Re: Willys MB build
« Reply #539 on: May 30, 2016, 07:13:27 PM »
ss cushion clamps, tape holes into the housing easy
