Author Topic: Willys MB build  (Read 195980 times)
Re: Willys MB build
« Reply #540 on: May 30, 2016, 07:15:24 PM »
Would rather weld than drill/tap 3/8" thick DOM...
Re: Willys MB build
« Reply #541 on: May 30, 2016, 07:29:02 PM »
bend a flat washer into an L shape.   tack weld the washer to the axle housing, zip tie brake line to the washer
Re: Willys MB build
« Reply #542 on: May 30, 2016, 08:32:42 PM »
That's perfect! Thanks Gif!
Re: Willys MB build
« Reply #543 on: May 31, 2016, 10:15:27 AM »
RuffStuff also has what they call Zip Tie Tabs to accomplish the same thing as the bent washer if you're into that sort of thing.
Re: Willys MB build
« Reply #544 on: May 31, 2016, 10:22:34 AM »
Yeah, I was aware of those.  Seemed... meh.
Re: Willys MB build
« Reply #545 on: May 31, 2016, 12:31:06 PM »
Weld on a 1/4"×20 nut. Bolt on cushion clamp.
Re: Willys MB build
« Reply #546 on: May 31, 2016, 08:19:45 PM »
I had thought of that too.  Ended up using Gif's idea.
Front plumbed
Re: Willys MB build
« Reply #547 on: May 31, 2016, 10:37:59 PM »
thats a legit track bar angle lol
Re: Willys MB build
« Reply #548 on: May 31, 2016, 10:47:01 PM »
Full droop plus
Re: Willys MB build
« Reply #549 on: June 01, 2016, 12:09:42 PM »
Front plumbed
One suggestion, you may want to replace the zip ties that you have holding the fittings of the flex lines with worm style band clamps.  I don't trust zip ties to hold the lines at the ends.
Re: Willys MB build
« Reply #550 on: June 01, 2016, 01:45:16 PM »
I’d weld the oe type brake line holder brackets to the housing in that location if I were concerned.
No issues with zip ties holding those to my suspension links for years in similar action though.
Re: Willys MB build
« Reply #551 on: June 01, 2016, 02:36:36 PM »
i use double big boy zip ties on my links with out any failures, but it gets torn down and re wrapped at least twice a year for some reason :(
Re: Willys MB build
« Reply #552 on: June 01, 2016, 07:05:25 PM »
Any flex lines that that have the potential to move are "hose"-clamped to the link and are quite solid.  The hose from the housing to the upper y-link won't move, it could have been plumbed as a hard line.
Re: Willys MB build
« Reply #553 on: June 02, 2016, 04:58:11 PM »
Front axle shafts assembled, short side installed.
Re: Willys MB build
« Reply #554 on: June 04, 2016, 06:03:20 PM »
Accessory bracket, alternator, and power steering pump installed.  Pulleys cleaned up.  Thermostat and new adjustable housing installed.
Fuse/relay block connected to the harness.  Power applied and pedal/throttle body and fuel pump feed tested good.
