Author Topic: Willys MB build  (Read 195954 times)
Re: Willys MB build
« Reply #390 on: March 29, 2015, 04:56:22 PM »
Been a while but things are getting done...
Re: Willys MB build
« Reply #391 on: March 29, 2015, 05:02:49 PM »
Final-cut to the front frame rails.
"D" ring brackets welded front, back, and inside
Corner reinforcement
Re: Willys MB build
« Reply #392 on: April 09, 2015, 05:38:07 PM »
Beadlock wheels back from powder coat.  Too nice.
Re: Willys MB build
« Reply #393 on: April 10, 2015, 12:12:18 PM »
Powdercoat? This is gonna be a nice machine!
Re: Willys MB build
« Reply #394 on: May 11, 2015, 04:14:33 PM »
One together.  Learning curve large.  That's a lot of bolts...
Re: Willys MB build
« Reply #395 on: May 11, 2015, 04:30:29 PM »
1/4" impact for the win
Re: Willys MB build
« Reply #396 on: May 11, 2015, 04:51:50 PM »
ready to wheel yet?
Re: Willys MB build
« Reply #397 on: May 11, 2015, 04:53:29 PM »
3/8" dewalt will do 4 KMCs 3x's around on one XRP battery and want more.
use a 5 gallon bucket if you didnt
Re: Willys MB build
« Reply #398 on: May 11, 2015, 05:28:35 PM »
Biggest part of the learning curve is the locknuts and gauging the amount of force to clamp the wheel vs. overcome the locknut friction.
Bucket used.  Not ready to wheel yet.  :P
Re: Willys MB build
« Reply #399 on: May 11, 2015, 09:16:14 PM »
10-15-20 ft lbs rings a bell.
Like smike said
Bucket is key.
Run them in with small impact is best.
And I soap up the beads.
Then I would always torque them around in stages.
Less attention was given on trail only wheels.
12 bolt H1's are much easier.
Re: Willys MB build
« Reply #400 on: May 12, 2015, 12:00:18 PM »
24 hrs and still at pressure!
Re: Willys MB build
« Reply #401 on: May 12, 2015, 05:04:50 PM »
Last three completed.  About an hour per unit.  Silicone used on bead lock side, bead sealer used on inner bead.  Air ratchet used and yields torque close to 20 ft-lbs.  Final rounds of torque using a torque wrench.  Aired to 20 psi for leak down test.
Whew.
jacel861
  • Full Member
Re: Willys MB build
« Reply #402 on: May 12, 2015, 08:24:49 PM »
No beadlocked spare? ;-)
Re: Willys MB build
« Reply #403 on: May 15, 2015, 05:26:44 PM »
No spare at all yet, beadlocked or other...
All still at pressure.  I'm calling it success.
Re: Willys MB build
« Reply #404 on: May 16, 2015, 11:12:19 PM »
Nice.
