Author Topic: Willys MB build  (Read 196263 times)
Re: Willys MB build
« Reply #405 on: June 13, 2015, 04:12:46 PM »
Driver side frame notch completed.  Ample room for air shock now.  Not excited about it but it should be fine.
Re: Willys MB build
« Reply #406 on: June 14, 2015, 09:30:07 AM »
Ding.
Fries are done!
Re: Willys MB build
« Reply #407 on: June 14, 2015, 10:26:44 AM »
Notch looks good
Re: Willys MB build
« Reply #408 on: June 14, 2015, 11:17:32 AM »
How thick is the "bridge"
Have room to gusset it somehow?
Re: Willys MB build
« Reply #409 on: June 14, 2015, 02:08:36 PM »
3/16" x 2
Will gusset or brace if space permits.
Re: Willys MB build
« Reply #410 on: June 22, 2015, 08:40:32 PM »
Upper shock mount completed.  1/4" with 3/16" gussets.
Re: Willys MB build
« Reply #411 on: June 23, 2015, 01:02:50 AM »
looks tight!
Re: Willys MB build
« Reply #412 on: June 27, 2015, 04:20:55 PM »
Matching frame notch and shock mount completed on passenger side.
Re: Willys MB build
« Reply #413 on: August 06, 2015, 05:34:50 PM »
Blown apart for welding...
carchameleon
Re: Willys MB build
« Reply #414 on: August 07, 2015, 08:06:22 AM »
looks awesome  :D
Re: Willys MB build
« Reply #415 on: August 07, 2015, 08:24:25 AM »
Glad to see it it getting used to being flopped. :)
Re: Willys MB build
« Reply #416 on: August 08, 2015, 09:00:56 PM »
90% welded.  Ran out of wire.  And gas.
Re: Willys MB build
« Reply #417 on: August 12, 2015, 11:08:33 AM »
Ha ha ha .
What he said!
Re: Willys MB build
« Reply #418 on: October 14, 2015, 04:53:41 PM »
Final assembly has begun.  I needed to get the pile of parts back into the shop to make winter storage room.
Engine got a hole drilled for the dip stick, oil pan installed.  Trans got the torque converter filled and installed and then mated to the engine.  Trans/t-case adapter kit assembled with reluctor ring, RTV, seals, and Loctite.  Then refitted the pair back into the chassis.
A little toaster oven heat made the reluctor ring slide on a bit farther
Finally married for good
Who needs a load leveler?
...and back to this point
Re: Willys MB build
« Reply #419 on: October 14, 2015, 05:44:04 PM »
thats a pretty big truck intake!
