Author Topic: Willys MB build  (Read 195952 times)
Re: Willys MB build
« Reply #360 on: January 20, 2015, 04:33:43 PM »
swayaway 2.5s
from kustom1
http://www.kustom1warehouse.net/Sway_A_Way_Racerunner_air_shocks_p/56700-114.htm
they were best price back before i knew better.  larger shafts. good shocks.  id go for the 2.5s for anything.  lower running pressures and everything is bigger / better
Re: Willys MB build
« Reply #361 on: January 20, 2015, 05:34:27 PM »
100% if going air shock. I'd run them again as well - I'm sure I'm well beyond what they could handle, now, but they were a really good first setup on that machine.
Re: Willys MB build
« Reply #362 on: January 20, 2015, 10:39:01 PM »
My 2.5 sway aways from kustom one warehouse have been flawless.
My 2.0's have have leak down issues.
Def go 2.5
Don't forget a swaybar. ;)
Re: Willys MB build
« Reply #363 on: January 20, 2015, 10:53:55 PM »
On a second note the ORI shocks have internal sway control...Something or other.
Slightly larger body diameter than a 2.5 air shock I believe. Maybe not.
 But I know DJ from Jon fund has had great success with them.
Re: Willys MB build
« Reply #364 on: January 20, 2015, 11:37:47 PM »
ORIs are goofy... Neat, yes, but a Complicated solution to a problem that coilovers already solved.
Re: Willys MB build
« Reply #365 on: January 21, 2015, 01:13:21 PM »
$85/corner difference between 2.0 and 2.5
Is it really worth it?
Re: Willys MB build
« Reply #366 on: January 21, 2015, 02:35:33 PM »
Whats your target weight? if over ~3800, I say worth it.
Re: Willys MB build
« Reply #367 on: January 21, 2015, 03:08:57 PM »
Def worth it. I've run both and it's noticable
Re: Willys MB build
« Reply #368 on: January 27, 2015, 05:47:12 PM »
mine are 2.0's with no issues, no idea of how they handle compared to the 2.5's for crawling
Re: Willys MB build
« Reply #369 on: January 31, 2015, 07:06:47 PM »
Finally got the "lead" out and got back into the shop.
Put together the last outer knuckle assembly and mounted tire #4.  Yea!
Also reworked the y-link because the original was not set properly.  This version cannot stay because it twists/pivots allowing caster change.  Once final ride height is set, I'll fab another fixed y-link.
Also borrowed the bender from a generous guy and started to make this look more like a shell of a Willys.  Unless you've done this type of work before, you cannot fathom how time consuming it is!  ...and I ran out of tube.  More coming next week.
Re: Willys MB build
« Reply #370 on: February 01, 2015, 11:16:13 AM »
and this is the "Fun and easy" part.
Its the last 10% that will test you...
Keep at it.
Re: Willys MB build
« Reply #371 on: February 01, 2015, 12:27:54 PM »
Coming along nicely Mark
tony
  • Come and take it
Re: Willys MB build
« Reply #372 on: February 02, 2015, 09:44:15 AM »
Looks nice
Re: Willys MB build
« Reply #373 on: February 02, 2015, 09:45:49 AM »
Keep at it.
Looks nice
yup and yup...
looks awesome..
Re: Willys MB build
« Reply #374 on: February 02, 2015, 12:18:57 PM »
Keep at it.
Test you, IT IS KILLING ME.....
