Author Topic: Tonys 2005 rubicon build  (Read 24413 times)
tony
  • Come and take it
Re: Tonys 2005 rubicon build
« Reply #60 on: August 17, 2014, 10:49:49 AM »
Gone for 2/weeks to Austin ... Installed new MC/brake booster last night.... Flushed brake fluid Now I know what good brakes feel like.  Especially after installing thatbig brake kit....
tony
  • Come and take it
« Reply #61 on: August 30, 2014, 10:54:25 PM »
So I come home from training.. Go to drive my jeep.  I have a squeak/chirp from brake booster when i step on brakes...  I have a very soft peddle and I can no longer lock up my tires.  Before I left when I bled my brakes it was with force.  Now it has a soft stream... Any clue what the issue may be..
New master
New brake booster with hardware
« Reply #62 on: August 31, 2014, 09:26:37 AM »
Sounds like a failed seal in the master?
tony
  • Come and take it
« Reply #63 on: September 29, 2014, 12:06:48 AM »
Crushed left rear shock... Steering wheel off center.  Got minor fixes.. All in all a great trip
« Reply #64 on: September 29, 2014, 08:25:53 AM »
check your toe, dont wana chew up your tires if something got knocked a little
good trip- your jeep works pretty well in the rocks
time to start saving for chromo shafts / RCV's!
tony
  • Come and take it
« Reply #65 on: September 29, 2014, 02:55:26 PM »
Smike . can you get me price on 2 FOX-980-24-645.  Thanks
« Reply #66 on: September 29, 2014, 03:25:33 PM »
you are out of your mind putting 240$ in shocks on one end of this thing
get some chromo shafts
put whatever 10$ junk shocks you can find on it   ;D
« Reply #67 on: September 29, 2014, 05:56:04 PM »
This.
The rear shocks get badly abused on a TJ.  You should also brace up the lower shock mounts because they bend.  Not "if" but "when."
tony
  • Come and take it
« Reply #68 on: September 29, 2014, 07:50:00 PM »
What shocks should I run.
« Reply #69 on: September 29, 2014, 07:55:31 PM »
Whatever is on sale at Summit.
« Reply #70 on: September 29, 2014, 09:50:16 PM »
http://www.rubicontested.com/TEN-Factory-4340-Chromoly-Jeep-Dana-44-Front-Axle-Kit-97-06-TJ-Rubicon-30-Spline.html
Dan can probably do something like that or cheaper. Email him dmrtransmission@gmail.com
tony
  • Come and take it
« Reply #71 on: September 30, 2014, 07:56:08 AM »
Thanks! Will do. That's the kit I was looking at.  Don't wana spend 1k on rcv
« Last Edit: September 30, 2014, 08:05:12 AM by tony »
tony
  • Come and take it
« Reply #72 on: September 30, 2014, 01:09:08 PM »
What's a good place in Roch to get aluminum sheets.  Making a deck cover
« Reply #73 on: September 30, 2014, 05:10:23 PM »
Pacemaker in Manchester delivers to Rochester everyday. Dan is the guy there.
can't remember where Smike and Mike get their aluminum.
« Reply #74 on: September 30, 2014, 08:55:45 PM »
KSD
Klein steel direct
