Author Topic: The nimble, lightweight crawler  (Read 15677 times)
Re: The nimble, lightweight crawler
« Reply #15 on: September 11, 2013, 09:39:08 AM »
You are a smart man, Ryan!
  • Paying Customer
« Reply #16 on: September 11, 2013, 09:43:51 AM »
This sounds like something that needs to go to Kirby's on 9/21
« Reply #17 on: September 11, 2013, 10:04:02 AM »
this is my one weekend. Could maybe sneak a day on the 28th or 29th but otherwise: booked solid
  • Paying Customer
« Reply #18 on: September 11, 2013, 02:18:10 PM »
waynes world twisted toys on 9/28
« Reply #19 on: September 14, 2013, 01:59:34 AM »
Maybe the gas tank leaks
Not a maybe.
15 gallons was too much.
I'll have to clean out the Dumpbus tank and put it in. Should just need to swap senders/pickups.
I fixed a lot of issues on this guy today. Bad grounds. Misaligned door, failed rocker, lack of 42s.
Didn't get to any plug, wire, filter, or fluid changes. Topped off oil and coolant. Should check trans level tmw. Didn't bring the deep pan and temp gauge I alread have nor fluid containers - but I have everything else with me. Clean air oil and trans filters, oil, ATF, plugs, wires.
I think the exhaust will drive me nuts. The stereo works, but am-fm at the park is slim pickins and I don't have any sweet cassettes!
« Reply #20 on: September 15, 2013, 06:28:24 PM »
So how did she do on her maiden voyage?
« Reply #21 on: September 15, 2013, 06:48:12 PM »
i was impressed!
« Reply #22 on: September 15, 2013, 07:23:55 PM »
made big rocks into smaller rocks
« Reply #23 on: September 15, 2013, 07:56:03 PM »
This truck is a machine. It was plowing its way thru everything.
Its proper name is "The Mule"
« Reply #24 on: September 15, 2013, 08:46:15 PM »
Apparently all it takes to follow really well-built rigs on 35s is a pile of 3/4 ton cut to fit 42s.
Didn't get to really work the hard climb out of Big O because I blew a rusty brake line, but it was doing the rock creek-sized stuff on the rest of Big O with relative ease.
To continue as a pilecrawler it needs the shifter fixed (way of of adjustment and falls from D to N on bumps. 1 & P are fine. N & R are hard to locate. Unless aiming to stay in D or hit N, respectively. Also needs rusty brake hard lines replaced.
The "floor board" works well enough. Fluid changes would probably not be a bad idea.
Not sure it's worth welding the axles that are there. Doubt I'll break anything the way they are which is nice, and it goes most anywhere a full body thing belongs.
There are a few options post-successful-drivtrain-shakedown:
I could probably put a floor in the driver side, put some square stock rockers in it, swap the fuel tank, and run it. Make new front control arms an inch longer and change nothing else to get the tires mostly out of the cab.
I could boat side the cab, lose the bed, lose the front outer fenders, and call it a truggy. Fuel cell, 120" wb, probably gear and disk the 70 and put the ford fronted in, air shocks?
Could lose all the body and put tube on top. Rest similar to above.
Could replace all frame and body with tube.
I think I'll look at some class rules and see what I could do and still be stock or mod class, and maybe help that sway my decision. Doubt it'll change much since I doubt I'd want to fit into those guidelines.
« Reply #25 on: September 15, 2013, 08:48:10 PM »
I forgot:
[attachment deleted by admin]
« Reply #26 on: September 15, 2013, 08:49:08 PM »
Couple more
« Reply #27 on: September 15, 2013, 08:53:07 PM »
a.k.a. = The Ass
...as in "get your Ass up these rocks"
« Reply #28 on: September 15, 2013, 08:55:54 PM »
What a pile of shit!! Haha that thing is just as bad as the Dakota
« Reply #29 on: September 15, 2013, 08:59:41 PM »
way better than the dakota, cause way less time money and effort was spent for 95% of the result
