Author Topic: 97 Dodge Ram 2500, AKA Shitty Dodge  (Read 62590 times)
« Reply #150 on: July 21, 2017, 08:57:24 AM »
clean out your cowl under the wipers.
I forget where the HVAC drain is, but that should drain out through the firewall, forward & down.
I'm starting to think it's rain water. the cowl under wipers are clean. Not sure where to start looking. I have leaky windshield but the amount that get poured out of floor vents seem to be too much for how little get leaked through the windshield seal.
« Reply #151 on: July 21, 2017, 09:02:29 AM »
after almost a year later, I finally have a full exhaust! procrastinating at the best. Dynomax 4" tail pipe, Dynomax 5" chrome tip from Rockauto. I relocated hangers to move entire exhaust up to put the exhaust tip high and out of harm way. PITA, but success!
I mounted one new tire, 315/70R17 Hankook Dynapro ATM. Deleted the front mud flaps and look like it'll clear just fine.  8)
Bald tires suck.
« Reply #152 on: July 21, 2017, 09:05:24 AM »
Next, is to install the tuner. To detune and tune out the smoke. After that, I think it'll be ready to be dropped off at "The Diesel Shop" in Rush for it's cold start's long cranking and heavy blow-by diagnostics.
« Reply #153 on: July 21, 2017, 09:18:02 AM »
You getting one of those in-cab fuel plate and AFC adjusters?
« Reply #154 on: July 21, 2017, 09:21:28 AM »
Yes. I already have it. Power Driven Diesel's AFC LIVE tuner. I can't wait to find out how much improvement it will make on driveability
« Reply #155 on: July 21, 2017, 09:25:13 AM »
neat, i was wondering how the word tuner and 12V worked
« Reply #156 on: July 21, 2017, 10:06:53 AM »
I think Nick's silver truck had one of those.
I just set AFC to barely smoke, ground my plate hard, and controlled EGTs and smoke w my foot
« Reply #157 on: August 13, 2017, 10:10:17 PM »
I think a better turbo will help a lot on EGT when towing through hills.
« Reply #158 on: August 13, 2017, 10:10:40 PM »
And paint the tailgate lol
« Reply #159 on: August 14, 2017, 08:59:48 AM »
pretty good distribution.
if you're happy with power but EGTs are high you might want to look to a hybrid to stay away from lag? not something I know a lot about, honestly, but I'd hate to give up quick spool searching for horsepower in mid-high range for my use at least.
« Reply #160 on: August 14, 2017, 09:11:33 AM »
water injection? totally talking out of my a$$...  :-
« Reply #161 on: August 14, 2017, 10:17:02 AM »
somethings wrong if you cant out pull me though steam valley at 10-12K lighter :)
our trucks are pretty close for the two times we were nose to nose, id say i was 2% more truck both times with our loads ignored. but that was hawging at 2800rpm 5th gear at 55mph for me
« Reply #162 on: August 14, 2017, 10:26:35 AM »
I'm thinking possible boost leaks, bad tuning, bad injection pump or something. I will investigate. I'm geared tall though.
« Reply #163 on: August 14, 2017, 11:07:02 AM »
My truck hawgs around the same weight though some gnarly hills on 84 and 81 with max EGT around 1200. There are two hills I grab 5th and run 60mph/2500rpm because they're steep and looooonngg.
Whatever turbo my truck has works really well above 1700-1800rpm. I cruise at 2130rpm at 70mph and it's perfect.
You are running 3.55s and 33s? You grabbing gears on hills?
Mike M has a lot of experience running a p-pump truck at that weight and more...
« Reply #164 on: August 14, 2017, 11:23:59 AM »
3.55 with new 315/70R17 tires. I drop to 4th on bigger hills.
