Author Topic: Found the problem with my cummins  (Read 7535 times)
« on: May 28, 2013, 12:47:56 PM »
Now to check the head and the block for flatness.  Hopefully tonights project if it is not raining.
Re: Found the problem with my cummins
« Reply #1 on: May 28, 2013, 12:52:13 PM »
How many miles?
You said it was running on 4 cylinders according to the injector line diagnosis method?
Did it get progressively worse or did it just run like shit one day?
« Reply #2 on: May 28, 2013, 02:14:40 PM »
Yeah 4 on the injector line diagnosis.
Just running along and then like ....  and that's all she wrote.
« Reply #3 on: May 30, 2013, 08:45:39 AM »
Doesn't look good
« Reply #4 on: May 30, 2013, 08:46:16 AM »
And piston # 6
« Reply #5 on: May 30, 2013, 08:53:39 AM »
No good
« Reply #6 on: May 30, 2013, 09:01:23 AM »
Ouch, run it  ;D
« Reply #7 on: May 30, 2013, 09:12:27 AM »
gasket and sell
« Reply #8 on: May 30, 2013, 09:13:41 AM »
Has another billionty miles in it!
« Reply #9 on: May 30, 2013, 09:35:39 AM »
Bad time of year to have this happen.  Looks like no camping or wheeling trips for a while.
The scratches aren't that bad...  going to see if the rings are still sealed and it the bores are round.  If they are, I may re ring it till to get me by till winter or just run it till I can pull it to rebuild.
« Last Edit: May 30, 2013, 09:38:42 AM by matt »
« Reply #10 on: May 30, 2013, 10:00:32 AM »
Water in the cylinders? High EGTs? How many miles?
« Reply #11 on: May 30, 2013, 10:52:05 AM »
Ouch.
I wonder if the bad HG gave it a hot spot. Looks like that bad part lines up with where the gasket was holed?
If the early and late 12v pistons match I have good stock pistons from my first motor. I think the bowls are the same but it would deserve a minute of research.
Mild hone in that hole and fresh rings on a good piston could probably get her happy again for a decent amount of time with minimal downtime and expense.
« Reply #12 on: June 06, 2013, 08:43:52 AM »
Any of you guys have a service manual for a cummins?  Looked on line and found nothing.
Specifically wear limits and max out of round for cylinders.  Got a bore indictor and cylinders are .002" out of round.  Want to double check size of bores before I just hone and rering that one cylinder.
« Reply #13 on: August 07, 2013, 11:25:23 AM »
So many dollars later.
« Reply #14 on: August 07, 2013, 11:30:24 AM »
And finally in and running.
My daughter picked the paint.  I was worried it was going to be pink or purple. lol
Runs great.  Smoother running, more power, and quieter.  New injectors are great.  Marine 370's....
