Author Topic: lowboy  (Read 128698 times)
Re: lowboy
« Reply #225 on: August 14, 2018, 11:05:52 PM »
Solid clicks and no goes has been my result since initial failure. Cleaned and tightened bus bars, no improvement.
Have you checked the ground bolt on bottom of the motor? It came loose on my trailer's winch and did similar.
Re: lowboy
« Reply #226 on: August 14, 2018, 11:38:59 PM »
just got as far as continuity (incl ground), not voltage drop.
still expect I just need to get new or repair motor. that alternator place is where I've been planning to go.
Re: lowboy
« Reply #227 on: August 17, 2018, 07:48:00 AM »
same result at first with a new 9K winch installed.  wiggled POS pos connection since i had already changed and cleaned negative frame connection and went from clicky and no go to clicky and go.
did not reinstall since i had already stowed old winch in the green monster.
had to use my truck to bend back my ramps to fit into your slightly smaller stake pockets on the trailer but worked well.
tools and supplies prepared for full cluster this trip as i haven't had one in a while and am due.
Re: lowboy
« Reply #228 on: August 17, 2018, 08:52:59 AM »
Good luck! Sorry for the additional necessary prep.
Re: lowboy
« Reply #229 on: August 24, 2018, 08:33:38 AM »
interested in a new winch for this unit?  300$ installed?
if not we can swap back yours to trouble shoot only 5 bolts easy.  I have to remount one of your cube lights too that i needed to disconnect for van bumper clearance.
I should be around most of this weekend.  tuning 5.3 Saturday with John at shop also.
Re: lowboy
« Reply #230 on: August 24, 2018, 11:08:43 AM »
Looking reasonable to not work this weekend, maybe I can get that bolt swapped and trans leak fixed from a month ago and shuffle the car over.
Re: lowboy
« Reply #231 on: October 12, 2018, 03:49:53 PM »
Ramp steel bought. That was a ~$250 theft, plus labor. Boo hiss.
Re: lowboy
« Reply #232 on: October 15, 2018, 07:49:04 PM »
Finally
Re: lowboy
« Reply #233 on: October 15, 2018, 09:43:55 PM »
Need to adjust one of the ramp holders. Front stop is too low on passenger side. So ramps are done but now trailer isn’t.
Wind sucks for welding weather.
Re: lowboy
« Reply #234 on: October 22, 2018, 07:03:06 PM »
Shame it didn’t get a paint job but it’s ready for service. Bleh.
Re: lowboy
« Reply #235 on: October 22, 2018, 07:04:46 PM »
I have a sprinter that can test it
Re: lowboy
« Reply #236 on: October 22, 2018, 09:41:28 PM »
Still waiting for details :)
To Boston MA tomorrow night, back weds evening.
Then maybe plan to go visit Joe and investigate pulling a radiator and seeing about what I can do to freshen any cracked or crusty things I find plumbing-wise. No other plans till wheeling nov 3
Would probably be nice to see if I can gets done heat out of it for that trip...
Re: lowboy
« Reply #237 on: October 23, 2018, 01:45:34 PM »
its a driver (runner).. at UCI buffalo.. need brought to Carter..
Re: lowboy
« Reply #238 on: March 10, 2019, 06:05:37 PM »
let me know what you want me to do to make this right    ::)
sheet of ice shifted and pulled out the brake away cable.  open trailer.  smoked a good flat on at least one of the front newer tires.  2 quick looks didnt find any other damage but needs another look over.   if it were mine id like what ever damaged to be replaced.  happen supper quick nothing i could do to pull over safely faster.
trade the winch or i can order new Gs that i run on my trailer depending on whats up.
bah!
Re: lowboy
« Reply #239 on: March 10, 2019, 07:23:57 PM »
What a shit luck.
