Author Topic: 1988 YJ Islander  (Read 11286 times)
1988 YJ Islander
« on: April 01, 2013, 01:48:48 PM »
Brother in law practically stole this thing. 1988 (we believe) 4.2L, stick, with no title so it's going to be a trail rig only.  Zero frame rot- was never on the road. Previous owner used it in Colorado to haul logs for his firewood. Chains and hooks dangling all over the thing. Huge Ramsey winch (I think about the same one MikeMike has on the Dakota) works great although mounted in the most bush-mechanic-craptastic way ever. No windshield glass, doors or top.
To Do: Wiring is a cobbled mess. Fix and get charging system back up to proper working order
             Remove random chains and hooks.
             Ditch winch frame thingy (bolted into body tin by 2-9/16" bolts. lol) And move onto front bumper.
             No grille... rig up something for lights? Fender Support?
             Roll cage of some sorts. B-pillar is there but tie bars to windshield long gone. We want something safer anyway.
Questions: Leafs are about dead flat on this thing. We'd like a touch more belly clearance without driveline problems. Budget is extremely tight. Any suggestions on something junkyard based or used?
I'm giving him my 35's to use. I know the axles won't be long for the world, but being open/open, if I train him to keep off the pedal he should be safe-ish for a bit. (We'll try to source some replacement shafts for the time being)
Now, best way to stuff them.....Fender trimming/removal is our goal here. We could care less about coverage so just hack away?
Any suggestions for mentioned problems or ideas for easy upgrades welcome!
Re: 1988 YJ Islander
« Reply #1 on: April 01, 2013, 01:59:42 PM »
Either used leaves and/or SOA.  Cut front fenders back to hood and hog out rear openings as needed.
Any pics of this pile?
« Reply #2 on: April 01, 2013, 01:59:50 PM »
are you looking for a vin?
« Reply #3 on: April 01, 2013, 02:01:23 PM »
buy pauls cherokee and swap tranny and Tcase
« Reply #4 on: April 01, 2013, 02:03:09 PM »
whooped leaves are a win SOA
remove front fenders
done
« Reply #5 on: April 01, 2013, 02:07:34 PM »
Extreme budget so VIN and Paul's parts are a no go. We're just hoping to get him up and running for a year or two. Maybe throw some money at it then. I'll get pics soon. But like I said, no rot. Excellent shape albeit stripped to nothing. SOA sounds like a plan. Probably start in this weekend while they tinker with the wiring.
« Reply #6 on: April 01, 2013, 02:08:10 PM »
done
done.
« Reply #7 on: April 01, 2013, 02:10:35 PM »
also, unhook front and rear frame mount brake line mounts, shocks might bottom out with spring conversion, but usually fine.
« Reply #8 on: April 01, 2013, 02:21:11 PM »
Brake/fuel lines are even still bright silver on this thing. Crazy.
1988 YJ Islander
« Reply #9 on: April 01, 2013, 02:42:39 PM »
Awesome J and J is your friend for YJ parts. They have like 6. J&J adventure should happen this weekend maybe?
« Reply #10 on: April 01, 2013, 04:10:33 PM »
Kind of a 50/50 chance of steering hitting? I'm reading some people make out fine with a drop pitman arm, some are fine as is and others have to go hi-steer or something else. Whooped springs make a difference?
« Reply #11 on: April 01, 2013, 04:20:55 PM »
i have the pitman off my ZJ if you need it. 1" drop compared to stock XJ/TJ/YJ
awl4928
« Reply #12 on: April 01, 2013, 04:23:49 PM »
Is he interested in slightly smaller duratacs instead of 35 km2s
« Reply #13 on: April 01, 2013, 04:25:57 PM »
Only if they're free  :P
awl4928
« Reply #14 on: April 01, 2013, 04:35:24 PM »
Your a nicer sibling than me
