Author Topic: GETTING STEEL TODAY  (Read 5017 times)
GETTING STEEL TODAY
« on: March 28, 2013, 08:26:01 AM »
let matt and i know what you need
it will be a late grab and load!
Re: GETTING STEEL TODAY
« Reply #1 on: March 28, 2013, 09:26:50 AM »
Can you fit a sheet of 16ga? 4x8 4x10 whatever they have?
GETTING STEEL TODAY
« Reply #2 on: March 28, 2013, 10:03:53 AM »
San you snag me some 2"x2" .25 wall square. Maybe around 10 feet
1/4" plate. Something around 48"x 24"
And some 1/8" plate. 6 square feet. Any sizes.
I'm flexible with amounts.
« Reply #3 on: March 28, 2013, 10:05:10 AM »
what is the best thing to use for a tabletop?
« Reply #4 on: March 28, 2013, 10:11:49 AM »
My benchtops that used to be Ryan's table top I believe to be 7ga. 3/16" thick. Very heavy and doesn't need continuous support underneath it - won't sag over a reasonable span. I'm a big fan of it.
1/8" over 1/2" plywood is much easier to deal with and has treated smike pretty well. I think that's his workbench, give or take.
« Reply #5 on: March 28, 2013, 10:14:46 AM »
I’m constructing my bench from 4x4 and 2x4 with a 3/4" birch plywood top... I would use this just to layer for a more durable top...
I guess the real question is what’s the thinnest (lightest) I can get away with… not worried about sag
« Reply #6 on: March 28, 2013, 10:36:37 AM »
« Reply #7 on: March 28, 2013, 11:01:24 AM »
ryan, i assume for floors so its ok if a corner is smooshed or has some dings?
taking matts truck so yess on the sheet
List
Matt
(2) 2x2x.250 x 24'
2x3x250 for truss'
1/4" plate
3/8" plate
sMike
(1) 2x2x.250 x 24'
3/8" plate 6-8" wide
Ryan 16g sheet
Spenser
« Reply #8 on: March 28, 2013, 11:06:08 AM »
Mike yours are 3/8" from ryans stupid thick table
My bench is 7 gage or 3/16" over 3/4" ply 2x6 frame, 2x4 stingers, with 4x4 legs, 2x6 shelf / leg support.   next table id go same top but bigger legs and frame the way i treat things
« Reply #9 on: March 28, 2013, 11:14:45 AM »
Matt you fail
not able to leave now and your truck has no fuel in it fail haha
i knew i should have charged up wonder2.0!
« Reply #10 on: March 28, 2013, 11:15:41 AM »
Yes, floors so whatever they have is fine.
GETTING STEEL TODAY
« Reply #11 on: March 28, 2013, 11:43:08 AM »
Thanks for the correction. Knew I could count on you!
Arie - really depends on what you're trying to do. 1/8" would be decent to keep the birch nice from grinding and minor drops while still being almost mobile. Could probably go even thinner if you're not planning to weld or plasma cut on it, but dropping a 5lb hammer on it (or 11.5" diff case) might leave a dent on thinner steel.
« Reply #12 on: March 28, 2013, 02:21:13 PM »
you guys still planning on being there at 330?
« Reply #13 on: March 28, 2013, 02:23:45 PM »
yes.
you bring frame on trailer or in MJ?
« Reply #14 on: March 28, 2013, 02:33:52 PM »
im going to drop it off @ the shop tomorrow.... way too much running around today.. didnt have a chance to get home..
I just want to match up the spring hanger and drop parts..  see what else is going on down there
