Author Topic: TurnedUp  (Read 105720 times)
Re: TurnedUp
« Reply #30 on: March 25, 2013, 03:09:48 PM »
sounds like one of those is a good idea then lol
Re: TurnedUp
« Reply #31 on: March 25, 2013, 04:11:15 PM »
Boost/pyro gauges ordered, should be here mid week
Picking up turbo tomorrow
Hopefully picking up fuel plate tomorrow
Need to get plumbing bits to reconnect AFC
Main vacuum line is sorta collapsed, need a section of that
Spool of 3/16" brake line and 3/8" fittings
My big block doesn't owe me anything, but this thing is an absolute pleasure to work on compared to that. Love it!
« Last Edit: March 25, 2013, 04:14:51 PM by Harrison »
Re: TurnedUp
« Reply #32 on: March 25, 2013, 04:16:58 PM »
Make sure your AFC isn't gutted. if it's not connected to boost and your truck isn't a complete retarded lump of a slob, you probably have no fuel control other than your right foot.
Re: TurnedUp
« Reply #33 on: March 25, 2013, 04:20:02 PM »
AFC covers the fuel plate, correct? Shares two bolts with the shut off solenoid? If so, we checked that and everything appeared to be there.
Re: TurnedUp
« Reply #34 on: March 25, 2013, 04:31:53 PM »
the armeture off the bottom of it that sticks down past the fuel plate is present? it may be gutted on top and pushed full forward...
if it's present + functional and not seeing boost, you'd get about 20% of fuel at most.
Re: TurnedUp
« Reply #35 on: March 25, 2013, 04:50:19 PM »
I do not remember seeing an arm that would have been sticking down past where the fuel plate goes. Add that to the list of stock parts I need to hunt down.
Balls, finding these little pump parts is not fun
Re: TurnedUp
« Reply #36 on: March 25, 2013, 04:59:27 PM »
In the meantime, gauges will tell me if I'm on the way to turning my pistons into aluminum puddles, no? Keep an eye on boost, pyro and what's coming out of the tailpipe and I'll be OK?
Re: TurnedUp
« Reply #37 on: March 25, 2013, 05:00:37 PM »
Thanks Mike, I'm learning a lot.
Re: TurnedUp
« Reply #38 on: March 25, 2013, 05:12:09 PM »
sounds fun.
i was thinking about a 12valve just because of the amount of oil i throw out from the shop.  i bet i could commute all year on waste oil :)
Re: TurnedUp
« Reply #39 on: March 25, 2013, 05:15:30 PM »
sounds fun.
I'm sure Mike is sick of messing with these things, and I probably will be one day myself. But I am fascinated by how simple it all is!  8)
It hurts my brain to try to think of all the shit going on under the hood of my Suburban hahahaha
Re: TurnedUp
« Reply #40 on: March 25, 2013, 05:22:02 PM »
id rather be sick of messing with things on free time, that frustrated at throwing 900$ or 1400$ bits at it with dealer monkey rates...
After Mike and i diagnosed my ECM to be bad and then convinced ourselves that couldntbe the case-  when 30Days later at a dealer and 2ECMs later it was,
we have the technology,
Re: TurnedUp
« Reply #41 on: March 26, 2013, 07:40:48 AM »
I saw a couple sweet deals on 24v's... just couldn't do it. Hahaha
Re: TurnedUp
« Reply #42 on: March 26, 2013, 09:42:12 AM »
yup
keep EGTs in check and you'll be fine. It may not be worth the time and effort to put that back to stock. Check Competition Diesel for someone who may be selling a complete AFC?
Re: TurnedUp
« Reply #43 on: March 27, 2013, 10:28:04 AM »
New turbo is in place minus exhaust. Broke v-band clamp, $30 from Napa.  :'(
Gauges came too. Gonna get those on tonight and hopefully take it for a spin and see how close I've been coming to puddling my pistons.
Re: TurnedUp
« Reply #44 on: March 27, 2013, 10:53:51 AM »
If you haven't been blacking out every intersection all the time you're probably fine.  Clear exhaust is almost universally safe.
