Author Topic: propane tanks  (Read 1199 times)
FallibleXJ
propane tanks
« on: March 10, 2013, 06:35:33 PM »
Looking for some propane tanks and brackets for a forklift. Wanting to covert the 5 to Propane and used/cheaper tanks would make it more likely to happen :)
Re: propane tanks
« Reply #1 on: March 11, 2013, 01:18:51 AM »
EBay for 100$-125$ all day long was where I git mine from.
FallibleXJ
Re: propane tanks
« Reply #2 on: March 11, 2013, 09:17:52 AM »
Yup, I saw those, but if i can save shipping...all the better.
Re: propane tanks
« Reply #3 on: March 11, 2013, 09:31:07 AM »
you wont- trust me.
dont bother to check welding places- they want money and will only do 5 year lease-
Like i said you will also need what i based my 800$ drop it off and drive it away quote:
Mixer / regulator / vapor hose / 1BB adapter Butterfly 250$
12' of high pressure LP hose / fittings  (good year air hose lasts a while but the acid in LP makes it stiff) 40$
4' of heater hose to splice into your heater core lines 5$
a 12vdc shut down or Vac shut down solenoid 30$
Tank or two  150$
Tank brackets 50$
Tank fitting 14$
clamps / ect 20$
throttle linkage adapt
fuel pump block of plate / disconnect
if your jeep is 1BB carb i think the mixer will bolt right on the way i had it setup.
Re: propane tanks
« Reply #4 on: March 11, 2013, 09:31:44 AM »
dont get steel tanks they SUCK!
shipping on an aluminum one was pretty cheap
