Author Topic: High Miler  (Read 302121 times)
Re: High Miler
« Reply #900 on: July 23, 2025, 01:08:56 AM »
Harry (among others?) was right with the split shift boot being the gear oil  on the transmission cause. Replaced along with center console cleanup and a radio replacement.
Re: High Miler
« Reply #901 on: July 23, 2025, 07:59:56 AM »
engine still running shrong?  nice
nick is on his 3rd VP44 this week and now the rear main is leaking on him.  his 2001 has been a headake
Re: High Miler
« Reply #902 on: July 23, 2025, 01:30:59 PM »
Just talked to him about batteries yesterday, didn't realize it had been that quick of succession on the vp44s. hope there's a cause, but I thought hat was all airdog and whatever goodness already. no good!
Re: High Miler
« Reply #903 on: August 02, 2025, 06:37:39 PM »
Had a hiccup with this today. While I was unloading the camper, truck idling, it surged hard 2-3 times and stalled after the last one.
Dash was going berserk with WIF and check gauges and check engine flickering and engine temp needle flickering, and preheat light lit solid. Heard an underhood relay flapping as well.
I should have tried to pull codes before I key cycled to see if the computer was alive and responding but I didn’t. Pulled codes fine after key cycling (nothing notable), and it fired up and idled fine for another half hour.
Will be driven to work to pick up some oil Monday, it better behave…
68 key cycles on the new computer.
Re: High Miler
« Reply #904 on: August 03, 2025, 07:18:47 PM »
 :o
Re: High Miler
« Reply #905 on: August 03, 2025, 07:22:30 PM »
looking like stealing your gooseneck might be the best option for me and Joe this weekend if that's still and option.  if you get stuck and need rocovery shoot me a message ill grab you if i can and then trade trailers.  planing on putting my truck on lift tomorrow or tuesday for checkup before NYS inspection friday AM before CT/NH trip
Re: High Miler
« Reply #906 on: August 03, 2025, 09:43:07 PM »
Sounds good. I should have put air in that tire today and looked it over while I was cleaning up but I didn’t. Maybe if I wake up early AF ( I never do. Still famously good at staying asleep :-/ )
Re: High Miler
« Reply #907 on: August 03, 2025, 09:51:51 PM »
might be shooting to waterloo wilkens at some point tomorrow to get an inspection so i can cancel my inconvenient Friday appointment.  i have a C02 tank in the truck
unknown time or if tomorrow or wed.  but if it could be accessible that would be cool.  i can look it over no worries
Re: High Miler
« Reply #908 on: August 03, 2025, 11:00:21 PM »
Yeah it’s accessible
Re: High Miler
« Reply #909 on: August 04, 2025, 08:48:57 AM »
Issues on the way to work today. One hiccup on the highway, on 64 in the village of Mendon, that gave me a dead pedal briefly. Long enough to hit the 4-ways but it recovered before I pulled over.
Then at an intersection red light while I was stopping, it shut down like I turned the key off. Able to immediately crank and re-fire, but it died about five times in a row after running for a second or so. Dash was doing the flicker dance again like when I was unloading the camper.
After having to take an unplanned side road due to dying in an intersection and pulling over at the corner, I’m dictating this while I drive down Jefferson Road and just about having palpitations at every red light.
P.S. - ran perfectly for another 20 minutes after this and got to work Just Fine®
« Last Edit: August 04, 2025, 11:31:27 AM by mr.mindless »
Re: High Miler
« Reply #910 on: August 04, 2025, 08:49:50 AM »
What a terrible dictation. I might try and fix that later. ?
« Last Edit: August 04, 2025, 11:31:52 AM by mr.mindless »
Re: High Miler
« Reply #911 on: August 04, 2025, 11:55:21 AM »
to-dos, I suppose:
triple check all ground points and ground straps
pull back loose harness connectors from removed parts including cooling fan. there are 3-4 under the hood and at least as many down where the transfer case isn't.
other than the dash flicker, a failing CP3 could make sense.
no TIPM codes, but I'd imagine it could cause these symptoms.
Chase that fuel tank level sensor issue and verify it's not wiring fault. maybe drop the tank and throw pump & sending unit at it ($171+ship) if no wiring issues found. I need to run wires to the tail of the truck for camper plug voltage drop and backup camera anyway. Will be a great way to spend probably half a day, but further motivation to keep cleaning up the shop.
borrow a scanner again or see if I can find a PC program to do constant logging of PIDs and voltage and whatever else. I did confirm that there are NO new codes stored.
Re: High Miler
« Reply #912 on: August 04, 2025, 06:10:02 PM »
Couple instances on the way home of hearing and seeing ‘check gauges’ and some or all needles going to zero reading. First time it was batt and rpm to 0, then back quicker than I could scan the rest of the cluster. 15m later I got 3-5 in a row of check gauges with 0 rpm and mph.
Had a suggestion to check the firewall CAN connection, that smells right. I’ll have to see where that goes through.
I wonder if unplugging the cluster or overhead makes the truck die.
Re: High Miler
« Reply #913 on: August 19, 2025, 12:09:34 AM »
strong replacement contender
https://www.facebook.com/marketplace/item/778152868007833/
he's had it for a couple years and like 6000 miles, He'd put a stand-on skidsteer on the bed and tow a dump trailer doing firewood work. could get another set of HD aluminum ramps with it for pretty cheap too.
only issue it's had since he owned it was that it died on him once in the middle of an intersection... three trips in to whomever was working on it, about a year ago, and it was a harness fault above the transmission. something got squished there. No issues since.
might be a clue on mine?
I'm going out there to look at this as soon as I get the chance, and think I'm going to do it. if sarah and I ever want to do cross country stuff with the camper by ourselves, something with 100k instead of 500k on it seems appealing. and a camper and small trailer (or even medium trailer) is 100% in reach here. might make sense to pass along the goose, depending? we'll see. I just want a reliable truck again!
Could fit a small permanent crane and a spare tire ahead of the camper on the bed, and the camper will overhang by about its bumper and that's it. genny exhaust would need rework, it's the furthest forward thing.
Re: High Miler
« Reply #914 on: August 19, 2025, 10:11:47 AM »
Would the deleted items be an issue with NYS emissions/inspections?
