Author Topic: High Miler  (Read 275835 times)
Re: High Miler
« Reply #525 on: May 31, 2016, 12:10:35 PM »
Makes sense. I have noise, not whistle.
Re: High Miler
« Reply #526 on: May 31, 2016, 02:08:56 PM »
link to the 20" one please.
I wanted to put a light bar behind my truck grille... but I think I can fit in something larger than 20"
Re: High Miler
« Reply #527 on: May 31, 2016, 02:38:22 PM »
Re: High Miler
« Reply #528 on: May 31, 2016, 02:41:37 PM »
Re: High Miler
« Reply #529 on: May 31, 2016, 05:26:08 PM »
Also dual row, not single. I needed a single to fit in the slot in my bumper
Re: High Miler
« Reply #530 on: May 31, 2016, 09:57:55 PM »
Any difference between single row and double rows?
Re: High Miler
« Reply #531 on: May 31, 2016, 10:04:58 PM »
Body height is all I cared about. Ryan might comment on technical differences...
Re: High Miler
« Reply #532 on: June 02, 2016, 01:54:34 AM »
Single row uses 5w Cree chips and better optics. The dual row is 3w chips. I would go single row,  the light is much better controlled.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Re: High Miler
« Reply #533 on: June 02, 2016, 09:10:26 AM »
your even typing like the thilands now ryan haha
Re: High Miler
« Reply #534 on: June 02, 2016, 09:35:35 AM »
Haha. I have been driving for days. My typing skills are suffering.
Should say "much more betterer"
Re: High Miler
« Reply #535 on: June 07, 2016, 03:21:43 PM »
We heard a few small parts exit the bellhousing on the way to PA. weird noises on engine cranking/startup that sound like parts rattling around haven't gotten any better on their own.
I just talked to South Bend, Aaron there sounds pretty concerned about the small pieces I heard hit the bellhousing, so I guess I should do something about that sooner than later. $600 plus shipping out of pocket for an exchange-for-new on the street dual disc. That seems pretty reasonable.
Only hesitation I have on that is that the transmission has been running significantly warmer for the last 3000 miles or so than it has in the past. Previously, I'd only trip my trans temp warning at 220Ëš on the VERY hottest of days, running heavy, in the hills, without stopping for 500 miles.
I'm now hitting that temp by the hill climbing out of Dansville with the single car enclosed trailer, and seeing peak temps of 260.
I just changed the fluid after about 50,000 miles. No significant chunks. No decrease in temp after changing.
Re: High Miler
« Reply #536 on: June 07, 2016, 03:26:09 PM »
trade this pile in for a big truck already     :D
no inspection cover on the bel housing to identify parts? id think you would want to do that asap before doing more damage to starter/ringgear/ plates ect
Re: High Miler
« Reply #537 on: June 07, 2016, 04:04:27 PM »
I confessed to Aaron at southbound that I had not tried to look, he said there's really not much to see without actual disassembly.
Maybe my bore scope might be able to see something?
As much as I keep looking and dreaming, priorities dictate another 1-2 years of service for this unit.
Re: High Miler
« Reply #538 on: June 16, 2016, 04:46:38 PM »
First and only writeup of G56 teardown that I found. Seems quite kind. http://www.cumminsforum.com/forum/94-98-powertrain/567275-diving-into-g56-step-step.html
I'd like to find a service manual for endplay specs and shim specs, and it looks like the jig on the second page of the thread would be very valuable if not neccessary for setting shims.
I think I'm planning to open the trans and do a visual on all gears and bearings, and set proper shimming for input/output shaft play. I've got to have a bearing going out or something along those lines with the huge temperature increase I've seen in the last ~5k miles even without seeing bad things on the magnet. I think a freshened clutch and going through the trans may help piece of mind for a future buyer too. I know I'd like to see that with a 400,000 mile truck. It wouldn't be worth any money to me but it would help me overlook the milage that would otherwise turn me off.
Re: High Miler
« Reply #539 on: June 16, 2016, 05:18:12 PM »
clutch kit in stock
