Author Topic: High Miler  (Read 302559 times)
Re: High Miler
« Reply #405 on: May 23, 2014, 12:22:50 PM »
buy a new drain pan, put the oil back in
ill admit i have started doing this with buggy diff fluid lol
Re: High Miler
« Reply #406 on: May 23, 2014, 12:23:16 PM »
explain to me how it will drain out, mister man!
also, explain how it'll cause damage from within the oil pan, eh? what am I missing here?
Re: High Miler
« Reply #407 on: May 23, 2014, 01:33:56 PM »
Run it, you can find a bus motor for it easy anyway.  :)
Re: High Miler
« Reply #408 on: May 23, 2014, 08:05:50 PM »
http://youtu.be/USW-MsWrI1Y
Re: High Miler
« Reply #409 on: August 22, 2014, 09:01:23 AM »
Cortese called me yesterday, recall parts are in. need to look at the rest of the steering this weekend and investigate exactly what this replaces.
I think I need a steering box. Truck has developed some play, and it's getting worse. Box is leaking. It's always had a drip, but when I parked it yesterday it was several drips. bah!
Re: High Miler
« Reply #410 on: August 22, 2014, 09:03:27 AM »
Interesting, right from the description on Rock for one of the boxes:
Quote
Front; 4WD; Power steering; WARNING: If the driver of this vehicle is experiencing "wandering" or "chatter", the likely root cause is frame flex, which causes excessive stress on the gearbox. Frame flex is common in this application and a brace will help combat this issue.
hundo plus core for the cheapest reman retail cost, that's nowhere near as bad as I was expecting.
Re: High Miler
« Reply #411 on: August 26, 2014, 09:28:05 PM »
No play at all in the leaky box. Grr.
Upper track bar bushing is shot. That's the only play in there.
Re: High Miler
« Reply #412 on: August 28, 2014, 03:32:58 PM »
My 'new' NAPA reman steering box is leaking now and since the day 1 it had that dead spot in the center. I'm planning to buy redhead's steering box sometime soon. I hope it'll not start one day suddenly pouring fluids out.
Re: High Miler
« Reply #413 on: September 11, 2014, 12:01:41 PM »
Re: High Miler
« Reply #414 on: September 11, 2014, 12:17:23 PM »
Put that in the dumper!
Re: High Miler
« Reply #415 on: September 11, 2014, 12:39:35 PM »
56# heavier, 1pt more gear oil, and 0.3" longer than the 9513.
Ratios look awesome. Can't find widths. Not sure I want to try to move my exhaust outside the frame again.
Should save the weight and go 9/10 speed. I don't need splits at all with the power band of the CR engine. It's as happy at 1400 as it is at 2600 and it REALLY pulls from 2500 well past 3k
High Miler
« Reply #416 on: October 23, 2014, 11:36:33 AM »
Looks like this ate a water pump. Could use a fresh belt too.
« Last Edit: October 24, 2014, 08:01:59 AM by mr.mindless »
Re: High Miler
« Reply #417 on: October 24, 2014, 08:03:26 AM »
Confirmed last night. Stopped at Regional, closest cummins has is in Albany. Tuesday or Wednesday unless I want to pay ups too.
Arie, you'll have an email shortly...
Re: High Miler
« Reply #418 on: October 24, 2014, 09:24:04 AM »
waiting
Re: High Miler
« Reply #419 on: November 02, 2014, 02:56:47 PM »
All set. Just need a gallon of water to finish tipoff and some water and coolant for stock.
Belt routing is insane on this thing. And fan and shroud are super tight to the motor.
