Author Topic: High Miler  (Read 302556 times)
Re: High Miler
« Reply #345 on: March 16, 2014, 06:50:35 PM »
considered - strongly. and dismissed.
Warm tires, cold day. All are in 2-5" divots. Only 4x4 or the locker working AND no ice under the pavement side would get me out. I'm np205 shopping now.
Re: High Miler
« Reply #346 on: March 16, 2014, 07:10:13 PM »
Sweeeet ride
Re: High Miler
« Reply #347 on: March 16, 2014, 08:11:26 PM »
Wait..  It's still stuck?
Oh mike, I'll come rescue you with my race car jeep on bald snows just to add to the shame
Re: High Miler
« Reply #348 on: March 16, 2014, 08:16:00 PM »
It needs to feel shame. It's going to sit there and think about what it's done!
awl4928
Re: High Miler
« Reply #349 on: March 16, 2014, 08:40:51 PM »
Do like we do with the tow trucks   lift up the rear rotate the tires so the ice is at the top drive out.bottle jack and 5 minutes done
Sent from my SAMSUNG-SM-N900A using Tapatalk
Re: High Miler
« Reply #350 on: March 16, 2014, 08:46:00 PM »
screw that.. do like a true new yorker and rock that baby free..
Re: High Miler
« Reply #351 on: March 16, 2014, 08:51:52 PM »
Spins in the holes. Chains through the hand holes would have it out in a minute if the locker was working.
Re: High Miler
« Reply #352 on: March 16, 2014, 08:54:19 PM »
rausch parking lot was a mess.  im amazed i got out.
Re: High Miler
« Reply #353 on: March 16, 2014, 09:48:59 PM »
Buy a 4wd?
Just sayin it is Rochester after all
Re: High Miler
« Reply #354 on: March 16, 2014, 10:38:07 PM »
You know, I got the locker to avoid this. And it would work, if it worked...
Re: High Miler
« Reply #355 on: March 19, 2014, 10:05:15 PM »
Successfully swapped an eagle for a ram tonight.
Still had to rock it and work for it pretty good.
Re: High Miler
« Reply #356 on: April 03, 2014, 09:19:52 AM »
Looked at the solenoid, have a chopped O ring. Hopeful for a simple fix.
Want to put a pressure gauge on the comp. May add a tank and make the comp come on with ignition when I rewire accessories, then just switch the solenoid. tcase will be air shifted; air horns would be nice sometimes too :)
There are several solenoid replacement options if needed. I do get oil contamination in the line, reading that I did suggests that really cleaning out the line can help things work as they should, but I'd figure that the gear oil on the wrong sides of the seals in the locker doesn't help things down in the diff either. Full disassembly is the only way to clean that out. I think lots of miles unlocked lets the oil weep past that seal when it's not under pressure. I didn't check the axle vent tube for restriction when I installed, that's another common means of contamination since if the diff builds any pressure it can really help oil get past that seal. I know it doesn't leak since I've let the thing sit for an hour or two locked and the compressor never kicked on - with no tank.
Still need to finish trailer wiring stuff, and I'd still like to get the toolbox deleted from the front of the deck and get a couple boxes underneath. Have some thoughts and plans for ramps as bedsides too, for tractor/atv/minitruck loading. Going to make them 10-12' long with a nested fold, probably build from 2"x.120 angle. Need to check some per-foot weights and make sure I'm not thinking of 150# ramps. I would like them to be under 50# ea so that may mean steel frame and aluminum tread?
Re: High Miler
« Reply #357 on: April 03, 2014, 09:38:26 AM »
For reference, my aluminum ramps are ~50# and 10' long.
Re: High Miler
« Reply #358 on: April 03, 2014, 09:41:07 AM »
Thanks. That doesn't sound like a likely target weight at all, then.
Re: High Miler
« Reply #359 on: April 07, 2014, 10:26:31 AM »
Worried about the injectors on this guy. It has none of the symptoms that I've seen associated with failing CR injectors: gaining oil, white smoke, rough idle & knocking, decreased economy. But above 20k rail pressure (which is generally accelerating 45mph+ under decent load) it feels like one hole isn't doing what it should. Almost sounds like an exhaust leak - it's very subtle.
Doesn't look like too big a job to pull the injectors to have them tested.
http://www.cumminsforum.com/forum/07-5-09-3rd-gen-6-7l-performance-parts-discussion/400343-how-removing-head.html
I'm at the end of my oil change interval, thinking of sending it to Blackstone to see if I've got more fuel in there than I should before digging in since it's so subtle. Would be nice to catch an issue before catastrophe for once though.
