Author Topic: High Miler  (Read 302585 times)
Re: High Miler
« Reply #300 on: November 02, 2013, 03:17:37 PM »
Charging system error of some sort.
Check gauges came on and stayed on leaving for dog class today, PIII told me I was at 12.1v. Let it idle through class since I wasn't 110% sure about restarting. Got home at 11.75v. No defrost and having to crack a window was a bit annoying. Nothing obviously loose or disconnected. Have had it on 15a charge for 2 hours now... Alt looks like a pain to remove w some egr cooler remains in the way.
Re: High Miler
« Reply #301 on: November 02, 2013, 04:40:09 PM »
Scrap yard time!!
Re: High Miler
« Reply #302 on: November 02, 2013, 07:55:01 PM »
A wire brush fixed my zj!
Re: High Miler
« Reply #303 on: November 02, 2013, 08:02:05 PM »
I thought you'd tried cleaning terminals. Good news!
These terminals look absolutely pristine. Low and steady voltage while running points strongly to alternator IMO.
I still have the one from Dumpbus. I give that a 4% chance of fitting.
Re: High Miler
« Reply #304 on: November 04, 2013, 11:31:45 AM »
http://www.summitracing.com/parts/sum-g1472/overview/
17$ sorry, dont remember what this was for but....
Re: High Miler
« Reply #305 on: November 04, 2013, 11:46:32 AM »
thats a $12 valve!
Re: High Miler
« Reply #306 on: November 04, 2013, 11:58:20 AM »
way over $1/#...
Re: High Miler
« Reply #307 on: November 27, 2013, 09:32:44 AM »
Been fighting with the trailer wiring on this since I realized backup lights didn't go through to the plug. The back on the existing socket is all potted so I can't pull it apart and fix it. I think they cut the back off a normal one to make it fit where it was so I need to poke a hole and relocate it. I cut a hole in the bed and ran a wire up for a gooseneck plug and got that all tied into the truck wiring after finding the GREAT resource of the ram body builder's guide. Gives full info on all the good stuff cab & chassis trucks come with.
Before I did the second half of the work at lunch yesterday and installed the rear socket I double checked the pinout and all was good except for the thing that forced my hand on redoing the wiring in the first place: the +12v from the battery hadn't been wired in at all before, but the RD/VT wire that's supposed to carry is is dead. Key off or key on. So I need to track that down now, or run a new wire from the front of the truck. Shitty.
I haven't tested with the P3 standalone on the trailer with the hydro actuator but I have this sinking feeling that it's not going to do any better after getting this all fixed as far as thinknig it doesn't have a trailer connected even though it's set to hydro, and is supposed to all play nice together.
Re: High Miler
« Reply #308 on: November 27, 2013, 09:42:49 AM »
You probaly checked the fuse for the trailer power, so thats all I got.
Re: High Miler
« Reply #309 on: November 27, 2013, 09:45:59 AM »
TIPM is still a totalfuckingmystery to me.
I think all fuses are good, I looked at the labels yesterday and only saw dedicated for trailer lights not the 30a battery feed. Need to recheck wiring diagrams. There should be a trick I get to play with existing wires to give myself an auxillary backup light activation switch too but I didn't get to test that without the battery feed at the rear and I couldn't find the underdash plug I need. That gives me switched power in the cab for a few things that I've so far just been good about not leaving on, too.
Re: High Miler
« Reply #310 on: November 27, 2013, 10:06:48 AM »
There has to be a maxi fuse for the trailer power. I would use a continuity tester on all the fuses to test it. Should take 41.3 seconds.
Re: High Miler
« Reply #311 on: November 27, 2013, 04:03:09 PM »
Fuse 19.
Re: High Miler
« Reply #312 on: November 28, 2013, 01:08:06 AM »
19 was blown. Replaced. Good.
Put in pigtail for rear plug but did not install. Taped off unwired ends. Rest of harness is sealed again and halfway dressed.
Need to hole saw for rear plug next to lic plate and wire it. Need to make sweet panel and hinge for mid-deck plug. Need to fix backup light relay on trailer and think about replacing the forward mounted backup lights. Need to find under dash plug and wire backup light override switch and make use of ign-switched power for ARB trigger and radar detector power supply. Tested the backup light override and it works as expected. I miss that switch from the old truck for night work, loading, and tailgating assholes with brights on.
Re: High Miler
« Reply #313 on: December 17, 2013, 02:15:39 PM »
Tinted!
Re: High Miler
« Reply #314 on: December 17, 2013, 03:35:58 PM »
Magazine, Mac, Dessi keep my windows like the Prezzie!
