Author Topic: High Miler  (Read 302146 times)
Re: High Miler
« Reply #105 on: March 20, 2013, 11:35:08 AM »
2600 retail I bet wholesale is 1300ish.  I called Marina just now, same price given. p/n 68053666ab - system shows one in stock in Cleveland.
I just found an ARB listing as well (RD139). comparable price to the True Trac at $980 to my door from Autoplicity.
http://www.justdifferentials.com/index.php?main_page=index&cPath=24_47_455
http://autoplicity.com/products/558688-arb_rd139_air_locker.aspx
I'd somehow feel better about spending that money on a selectable locker instead of essentially a stock replacement part. I guess it's my upgrade-itis?
Re: High Miler
« Reply #106 on: March 20, 2013, 12:11:53 PM »
Hold. I may have found something for you. I will text you.
Re: High Miler
« Reply #107 on: March 20, 2013, 12:30:47 PM »
i have some contacts at AAM that are probably in Michigan i might be able to dig up and see if we could get a sample sent out...hmmm.
High Miler
« Reply #108 on: March 20, 2013, 01:42:42 PM »
I can get an arb to my door for cost plus shipping from mike at DnD. Think he said 880, and 50-70 in ship. If he does FedEx ill run shipping the cheapest route instead - but drop ship I probably don't have that option
Re: High Miler
« Reply #109 on: March 20, 2013, 03:00:07 PM »
Man that is a expensive axle break
Re: High Miler
« Reply #110 on: March 20, 2013, 04:25:58 PM »
tell me about it. this is fuckinretahded
Re: High Miler
« Reply #111 on: March 20, 2013, 04:30:04 PM »
Run it.
Re: High Miler
« Reply #112 on: March 20, 2013, 04:36:52 PM »
Then after unknown time it'll break, waste the shaft too, and strand me. sounds like a good plan, right?
Re: High Miler
« Reply #113 on: March 20, 2013, 04:50:32 PM »
Run it.
Re: High Miler
« Reply #114 on: March 20, 2013, 04:55:15 PM »
cary a ready welder quitcherbitchen
one wheel peal a lincoln locked tow rig!
Re: High Miler
« Reply #115 on: March 20, 2013, 05:12:44 PM »
ARB will be on the way from East Coast Gear Supply ctsy of Mike at Down n Dirty.
ECGS had a cheaper truetrack than I'd found anywhere else too, but still too much in comparison to the ARB price.
Re: High Miler
« Reply #116 on: March 20, 2013, 05:24:04 PM »
ARB seams silly, dont you need an air compressor now and bs?
Re: High Miler
« Reply #117 on: March 20, 2013, 05:34:32 PM »
Because I don't have one of those already set up in the other truck? Beyond easy. Sucker is gonna end up parted out anyway, no bites. Annoying.
it'll be way more useful than a limited stuck in shittyness, and will be much nicer stability wise going down shitty roads. One wheel peel keeps you in a straight line. I was thinking about the white knuckle flat towing in PA and how an open rear diff would have been much safer on ice like that. That's what sold me.
High Miler
« Reply #118 on: March 20, 2013, 06:26:51 PM »
How'd we get from axle shaft to a fuckin ARB?  Turn it off!
Re: High Miler
« Reply #119 on: March 20, 2013, 06:29:17 PM »
because the broken axle shaft cracked the carrier and the fuckers A) don't seem to exist used and B) cost a fucking fortune new
