Author Topic: Moose  (Read 74304 times)
Re: Moose
« Reply #210 on: June 17, 2013, 09:42:50 AM »
what was the snazzy oil filter adaptor thing for cooler lines and pressure sender you had on the profender buggy?
i cant find it on summit
Re: Moose
« Reply #211 on: June 17, 2013, 09:47:24 AM »
Re: Moose
« Reply #212 on: June 17, 2013, 10:05:35 AM »
Yea, it was something like that, I dont remember it having a thermostat.
My 6.0 had a factory oil cooler line set up, so I just used the adapter plate for oil pressure
Re: Moose
« Reply #213 on: June 17, 2013, 10:11:45 AM »
ok
what shifter did you use?
im getting lazy
found 144" throttle cable instock at summit 45$!
Re: Moose
« Reply #214 on: June 17, 2013, 10:13:14 AM »
I used the gated Winters shifter, it is a nice unit but not cheap.
http://www.wideopendesign.com/Product/97/Art-Carr-Winters-Shifter.aspx I used the flush mount.
Re: Moose
« Reply #215 on: June 17, 2013, 10:17:14 AM »
you get the installation kit to?  225$ meh  nice though
Re: Moose
« Reply #216 on: June 17, 2013, 10:21:34 AM »
I thought it came with everything you need. Those install kits might just be if you are changing transmissions.
Rock gate would be a nice gate for it, going from r to d would be much faster than witht he normal gate.
Re: Moose
« Reply #217 on: June 23, 2013, 11:19:28 PM »
5.38's ordered for this guys instal
Re: Moose
« Reply #218 on: June 24, 2013, 10:24:07 AM »
Alternator and PS pump both need to be replaced. Transmission is not shifting correctly, it seems. Need to investigate that.
It gets super hot inside this buggy, heat shielding and exhaust relocation are needed.
Brakes dont work, need to investigate that. Residual valves may need to be added, or a bigger master cylinder.
Liz_rn
Moose
« Reply #219 on: June 24, 2013, 10:10:08 PM »
No more buggy riding for me until the heat issue and brakes are taken care of. Flying backwards into a tree due to lack of brakes is not a good time.
Re: Moose
« Reply #220 on: June 25, 2013, 12:04:49 AM »
liz is whining like a middle schooler
Liz_rn
Moose
« Reply #221 on: June 25, 2013, 06:43:29 AM »
Yes I am.
orange anchor
Re: Moose
« Reply #222 on: June 25, 2013, 06:47:53 AM »
Liz that wasn't a tree that us pushing you up the hill.
Re: Moose
« Reply #223 on: June 25, 2013, 07:28:03 AM »
Liz_rn
Moose
« Reply #224 on: June 25, 2013, 08:29:21 AM »
A little warning next time on that one would be great :)
