Author Topic: Moose  (Read 62254 times)
Re: Needs a name buggy
« Reply #15 on: November 10, 2012, 08:44:01 PM »
This is the engine I have, 142hp, need to find a harness and computer
B18B1
NON-VTEC
Found in:
1994–2001 Acura Integra "RS/LS/GS/SE" (DC4/DB7)
1992–1996 JDM Honda Domani (MA5)
1993–1994 JDM Honda Inta (DB7)
1996–1999 JDM Honda Orthia (EL1)
Displacement: 1,834 cc (111.9 cu in)
Compression: 9.2:1
Bore: 81 mm (3.2 in)
Stroke: 89 mm (3.5 in)
Rod Length: 137.01 mm (5.394")
Rod/Stroke Ratio: 1.54
Power: 142 hp (106 kW) @ 6300 rpm & 127 lb·ft (172 N·m) @ 5200 rpm
Redline: 6800 rpm (7200 rpm on JDM Domani)
Rev Limit: 7200 rpm
Transmission: Y80/S80
JDM version is marked B18B on the block without any number.
JDM version has a compression 9.4:1 where the usdm version is 9.2:1.
JDM version has a higher compression ratio which results in higher hp and tq levels than the usdm version.
Needs a name buggy
« Reply #16 on: November 11, 2012, 08:16:22 AM »
USDM, huh? I'm pretty sure only Japan OR the US can be domestic. And I'm pretty sure USEM (or world export depending on Europe) would be a wee bit more accurate. Stupid ricers!
« Reply #17 on: November 12, 2012, 09:33:14 AM »
I could use some help lifting the motor out of the trailer. Its a 2-man job.  ;D
Needs a name buggy
« Reply #18 on: November 12, 2012, 10:27:49 AM »
« Reply #19 on: November 12, 2012, 11:23:35 AM »
Tonight? Tomorrow night?
Im pretty open these days.
« Reply #20 on: November 12, 2012, 12:01:23 PM »
you did mention that part :)
want me to see if we need any network engineers here?
« Reply #21 on: November 12, 2012, 12:03:08 PM »
That would be fantastic. Thanks
« Reply #22 on: November 12, 2012, 01:09:38 PM »
For future reference
Keywords rear steer
http://www.howeperformance.com/pdfs/rockcrawlrearsteer.pdf
« Reply #23 on: November 12, 2012, 07:34:58 PM »
I can swing by sometime. Let me know!
« Reply #24 on: November 12, 2012, 07:39:20 PM »
its raining, and beverage 2 was gone a bit ago,
when is the unavailing and naming happening
« Reply #25 on: November 14, 2012, 09:04:56 AM »
Smike, do you have any 1.5" .120" tubing you can make me a new shock hoop? The one side is pretty bent, i think it will be easier to put a new one in than try to straighten this one.
I can cut it out and bring it up to copy.
« Reply #26 on: November 14, 2012, 09:31:13 AM »
i have zero 1.5" in my shop- this has annoyed me a few times.  next tube order will have a couple sticks.
does erik have a 180 die for 1.5?
« Reply #27 on: November 17, 2012, 12:16:16 PM »
Just saw this. I would like to try it for a CL ad.
http://joel.net/EBONICS/Translator
Needs a name buggy
« Reply #28 on: November 17, 2012, 01:48:07 PM »
Yo ah gots uh 2001 Nissan frontier fo' sale. Souther `64, nahh rust at all. 4 cyl 5 speed 2 wheel cruize. New battery you know das right!
Needs a name buggy
« Reply #29 on: November 17, 2012, 10:40:13 PM »
I'm loving those comments
